fuel pump stutters
Old Feb 2, 2012 | 09:16 PM
newblder's Avatar
newblder
fuel pump stutters
I went out to start my truck this morning and when i turned the key on and the pump came on it stuttered several times. I say stuttered because it never stopped. The sounds of the pump changed for a few seconds. It started and drove fine. Its done it 2 or 3 times today. I crawled underneath the truck and had my wife turn the key on so I could see if I could see anything. Its definitely coming from the pump under the driver. There were no leaks. Is my pump going out?
Sorry about the explanation of the noise. Its hard for me to describe.
Old Feb 3, 2012 | 07:32 PM
F350-6's Avatar
F350-6
Sounds like it's time to check your fuel pressure. My pump would cycle on and off continuously when an o-ring in the FPR failed. My fuel pressure was bouncing up over 100 psi and causing the pump to shut off until pressure came back down.
Old Feb 3, 2012 | 08:44 PM
snakedoc's Avatar
snakedoc
same here when my FPR was stuck on 100psi it would sound like it was going to vibrate off the rail.
Old Feb 3, 2012 | 09:12 PM
newblder's Avatar
newblder
Is the FPR at the bowl? I recently installed an FRx kit but used the gold spring since it was the one that was recommended. I need to go look at getting a gauge to see where my pressure is at.
Old Feb 3, 2012 | 09:38 PM
snakedoc's Avatar
snakedoc
that is it, that FPR is bad about getting stuck if you play with it, the same thing made mine stick. you can make a gauge set up for $20 that can read fuel or oil psi.
the spring you put in rides on the FPR plug.
Old Feb 4, 2012 | 06:33 AM
F350-6's Avatar
F350-6
There's also a chance you didn't get the spring centered in the hole and that is what's causing the high fuel pressure.
Old Feb 4, 2012 | 08:36 PM
newblder's Avatar
newblder
That was it! I just saw this post today and checked it. It sounds a lot better. Thanks.
sparks717
Nov 25, 2023 09:59 AM
crzycrazycarl
Apr 8, 2010 09:52 AM
v8xploder
1978 - 1996 Big Bronco
Oct 12, 2009 05:46 PM
jas88
Apr 1, 2008 09:49 AM
4X4 IN REFUGIO
Aug 31, 2006 02:36 PM
