I have changed everything
Old Mar 4, 2012 | 10:45 PM
  #31
kedwinh's Avatar
kedwinh
You don't have a resistor wire or ceramic resistor? Never seen one like that, well till they started using computerized and newer type ignitions. All the cars I've ever seen or worked on in the last 45+ years used some form of resistor to cut voltage to the coil in run mode.
Old Mar 5, 2012 | 06:29 AM
  #32
ftrk66's Avatar
ftrk66
Then I have to check my ignition system, but I am driving my truck since 2002 like this, no resistor ceramic thing.
Old Mar 5, 2012 | 02:28 PM
  #33
kedwinh's Avatar
kedwinh
If it doesn't have the white ceramic style resistor, usually mounted on the firewall, it might have a resistor wire in the wiring harness. Or if you no loner have the old round style coil and instead have the newer square style it probably doesn't need a resistor circuit. The newer type coils can take full battery voltage in run but the older round ones need voltage to be around 7v in run or they don't last long.
Old Mar 5, 2012 | 03:06 PM
  #34
ftrk66's Avatar
ftrk66
Still didn't check if my truck ignition is the resistor type or not, but I do have the round type coil, see my truck is 66 year model and that square type coil wasn't exist at then, it worth searching on my truck ignition system, maybe I am missing that ceramic resistor and its affect on engine performance.
I drove my truck 125 miles this afternoon with couple of stops at the gas station and at a friend of mine who has a property in the suburbs. Driving between 65-70 mph is fun with engine responding to acceleration in all speeds, just feel like idle is a little low, will see that tomorrow.
Is the resistor wire the one coming from the starter solenoid, mine is a common wire like all others, what it looks like?, does it has affect on the voltage going to the coli or out to the distributor?.
Old Mar 5, 2012 | 05:01 PM
  #35
critterf1's Avatar
critterf1
Voltage to the COIL should be approx. 9 volts.
Old Mar 5, 2012 | 08:21 PM
  #36
ftrk66's Avatar
ftrk66
Thanks Critterf1, I check the voltage again.
Old Mar 5, 2012 | 08:57 PM
  #37
ctubutis's Avatar
ctubutis
The resistor wire leads from the ignition switch to the coil, I think they're pink and seem to be lots thicker than a standard wire in that loom.
I forget their ohm measurements - something like 1.1 to 1.3 ohms but don't take my word on it.
Old Mar 6, 2012 | 12:14 AM
  #38
kedwinh's Avatar
kedwinh
Thank critterf1, couldn't remember exactly what the voltage was.
IMO it really isn't worth the effort to find it unless you just want to because it's probably buried in the wiring harness. As long as your truck is running it's good. And if it didn't have one you would have probably already fried the coil. It's one of those things that you just don't think about until it dies.
But if it ever goes to starting but dies as soon as you let up on the key that would be the first thing to look for.
Old Mar 9, 2012 | 08:10 AM
  #39
ftrk66's Avatar
ftrk66
Now I got 214 Miles on the engine after installing all the new ignition stuff with the new Carter YFA 1 brl carb, engine works great except a little rough at Idle, no misses in all speeds.
I figured that rough idle is due to low vacuum, and IMO the correction is adjusting the idle speed with the mixture screw, maybe it is below specifications.
Old Mar 9, 2012 | 09:05 AM
  #40
AbandonedBronco's Avatar
AbandonedBronco
Certainly give that a try. Once the truck is warmed up, it will honestly take you about 5 minutes.
Start the truck, warm it up, pop the hood, hook up the vacuum gauge, rotate the idle mixture screw until you get peak vacuum.
Glad to hear the truck is running well though! Are you overall pleased with it?
Old Mar 9, 2012 | 12:28 PM
  #41
ftrk66's Avatar
ftrk66
Yes I am A.B, the Ford F100 truck specially the 66 year model is a unique in Saudia Arabia and the Golf area. I love cruising the highway on this truck, lots of folks admire and have a happy smile.
With that twin I beam suspension, truck height from ground, and stability on road makes driving a real pleasure. There is a public model around here which kinda obsolete in the U.S, it is the F350.
Back to idle adjustment, don't you think the peak vacuum will throw the idle RPM out of limit?. I will do that tomorrow. Thanks for sharing your experience.
Old Mar 9, 2012 | 12:31 PM
  #42
AbandonedBronco
Sounds like an awesome truck to have. Very cool.
For idle adjustment, it's very possible that it'll change your idle RPMs. If it does, that means it was out of adjustment.
If the idle RPMs change when you adjust for peak vacuum, adjust the idle RPMs until they're back where they should be. Once you reset the idle RPMs, readjust the idle mixture screw again for peak vacuum. If it changes the idle RPMs, adjust the RPMs again. Repeat, repeat, until they're both happy. Usually, it only takes once or twice.
Old Mar 9, 2012 | 12:57 PM
  #43
ftrk66's Avatar
ftrk66
Very clear, will do that tomorrow. Thanks.
Old Mar 17, 2012 | 07:28 AM
  #44
ftrk66's Avatar
ftrk66
On the 11 Mar I done what AB told me, that was easy and resulted in smooth idling, and real smooth. Using the mix screw to increase the vac and then adjust the idle speed has a noticeable effect on engine idling.
I left my town in a 1200 mile cruise, had no problems, the cruise was very nice. I went to join a classic Ford truck gathering, will will see the photos I took in another thread titled" We do have Ford truck super-national".
Thanks for all of you who shared me your ideas in this thread. It is really good experience.
Old Mar 18, 2012 | 09:43 AM
  #45
AbandonedBronco
I'm glad that helped! Sounds like you're getting your truck running how you want it. I'm glad to hear it.
ATC Crazy
Jul 19, 2011 06:12 PM
dfwrider
Jan 1, 2011 06:34 PM
Ratt617
Feb 21, 2010 06:11 PM
fordmanjoe1987
21
Mar 12, 2008 09:20 PM
1 Big Mike
19
Nov 2, 2002 10:34 PM
