how to disable navigation lockout
- thanks
- thanks
I thought ecoboost was on F150's, what engine do you have in your F350?
" There is no need to add any switches or cut any wires. The Sync Lockpick is simple plug and play making it is easy to install or remove and perfect for leased cars. " there is no need as you can but this is simple to just plug and play? Because I would rather put a switch in than spend 240$ which is kinda high. You could add a switch in earlier navigation systems... Why not know?? I have done research and can't seem to find if it works on newer models.
The new systems use the nav feature and if it senses vehicle movement and immediately disables and locks out certain functions to keep you from taking you eyes off the road and hurting yourself or someone else. Not saying I agree or disagree but a lockpick is on my list of future upgrades.
Now if they could only do something about those that text while driving down the highways at 70+ mph.
So I tried out the SyncLockpick...
Installation wasn't a big deal. As was said before the hardest part was getting all the wires to fit behind the radio after install. Even pulling the center dash off was easier than expected. The plug and play wire harness was awesome.
Im a huge fan of being able to use the nav system while in motion especially when I have a co-pilot. So the idea behind the SyncLockpick was exactly what I was looking for. It's nice to have your routes planned out before you start moving, but like always, a need for last minute updates or searches always seem to come up during the drive.
My lock pick worked as advertised during the first hour but after that it just went haywire. Causing the radio to disconnect my blue tooth devices and turn on and off intermittently. Then it would turn on and show the backup camera while i was driving down the highway.
I'm sure it was just a bad unit. But the main reason I returned it for refund instead of exchange was I wasn't happy with only getting 60 seconds to input my addresses or do my searches.
Don't know about the rest of you but 60 seconds isn't nearly enough time for me. You can extend the lockout by holding the phone button down for an additional 3-5 seconds but then that's just one more step to accomplish. In order to hand jam in your addresses or search for your Points of interest (POI).
For $240 I wasn't impressed enough to keep it. I would hope for that kind of money it would make the Nav system operate like it did when you aren't moving for as long as you needed it or until you are finished. That was really my only requirement.
Can't really comment on the DVD player use while in motion as I never attempted to use it. But the backup camera did work in motion... although it wasn't commanded to...
Like many others have mentioned, using the voice commands isn't too bad once you get used to them and turn off the acknowledge requirement so it doesn't echo everything you say before it executes the command. All the commands that are locked out can be used with the voice. Just look at the screen and say the option you want whether it's greyed out or not. I practiced this after I removed the SyncLockpick in order to see if it was too difficult and I needed to exchange the Synclockpick for another one or just return it. Like I said earlier it wasn't bad at all. So back goes the Synclockpick for return minus shipping and restocking fee.
Overall impression of the Synclockpick... It was easy to install and if all you want it to do is be able to use the DVD while in motion or view rear camera it's a great buy. My main purpose for the purchase was using the Nav System while in motion. It worked but for only 60 seconds at a time. Granted you can extend the length of time by pressing and holding the "phone" button for 3-5 seconds at the end of each 60 second period. In my opinion For $240 it was way overpriced for what I would use it for. I relegated my searches for POIs and address to my iPhone and just use voice to input the address into my Nav system. Much more user friendly and accurate. It's amazing how you can do a search for something on your nav unit by category and it won't show up but if you put the actual name in... there it is. So frustrating!
iPhone with google voice works like a champ.Don't know why manufactures seem to make the new Nav systems so user UN-friendly... I know it's all the laws and liability issues but how about making the user take some responsibility... after all the speed limits are 70 mph but nobody sues the car manufacture because they get into an accident and the manufacturer made a car that goes faster than the speed limit ... but that's another discussion all together...
