Finally got my egr delete in, I'm calling into work tomorrow so I can get her back together. I do have a question, its kinda a no brainer but I just want to make sure. I did not get the up pipe for the delete just the basic delete. It came with a circle plate, that goes in the y-pipe and use the clamp to block that off correct?
Yes Sir
Use the Marmon clamp to secure the Plate to the Uppipe
FYI the Ypipe is the exhaust pipe that conects right at the turbo the one that conects both exhaust manafolds to turbo
And then leave the EGR Valve installed the intake manafold plugged into the wire harness and your good to go
Hey well I got the truck all back together BUT it won't start. It seemed like it wanted to the first few times but now it just cranks and doesn't seem like it wants to start. Any ideas?
I only let it crank for about 30 sec. Then stop I don't want to burn up the starter, can and should I let it crank longer? I'm getting 48 volts from the ficm and my icp is 0.3 I don't fill the hpop either
Blade you are the freaking man, went out and cranked it a few more times and bam fired right up!!! Then I noticed that the was oil everywhere and then noticed the oil feed line at the top of the Turbo was way way loose, I think that was my buddy's job, lol. Well she is alive and I well get some oil tomorrow and top her off, thank you everyone for all there help this site is amazing, I'll keep u all updated!!
