Request: Excursions on factory 20s
Old Feb 1, 2012 | 11:08 AM
BuiltFordTough!'s Avatar
BuiltFordTough!
I would like to see some pictures of excursions with factory 20s on them.
Old Feb 1, 2012 | 04:49 PM
big315's Avatar
big315
I have seen one before. Man, does it look good!
Old Feb 1, 2012 | 05:20 PM
ComputerCowboy's Avatar
ComputerCowboy
dneil10 has them
see his thread https://www.ford-trucks.com/forums/1...ght=back+stock
I think he might be getting rid of them since he is dropping the truck back to stock.
Old Feb 1, 2012 | 06:46 PM
pdombrowicki's Avatar
pdombrowicki
Here is my last EX 2005 with 20's
Old Feb 1, 2012 | 06:59 PM
BuiltFordTough!
any lift on that or spring mods? any rubbing looks close on the front.
Old Feb 1, 2012 | 07:07 PM
pdombrowicki
NO lift RAS in the rear. Lock to Lock on the steering wheel there is a little bit of rubbing but nothing to worry about.
Old Feb 2, 2012 | 06:51 AM
BuiltFordTough!
Did you use 2" spacers to offset the rim?
Old Feb 2, 2012 | 06:58 AM
pdombrowicki
<br />
<br />
Yes you have no choice.
Old Feb 2, 2012 | 07:04 AM
BuiltFordTough!
did you do the full 2" or 1.75"
Old Feb 2, 2012 | 07:12 AM
Bigdaddybus's Avatar
Bigdaddybus
Heres mine with 2" spacers and stock 275/65/20 GY wrangler a/t's
Old Feb 2, 2012 | 07:16 AM
BuiltFordTough!
Do you rub at full lock as well?
My 350 rubbed at full lock and i hated it it was a crew cab long bed i needed all the turrning power i could get.
Old Feb 2, 2012 | 07:22 AM
Bigdaddybus
I get no rubbing at full lock. I recently purchased the truck and other than Monroe reflex shocks and a dual steering stabilizer I am not aware of any other suspension mods.
I'm interested to see if it rubs when I hook up my camper with load leveling hitch for the first time.
Old Feb 2, 2012 | 07:31 AM
BuiltFordTough!
Your an 05 do you have leafs to coils up front?
Old Feb 2, 2012 | 07:52 AM
Hunter,DDS's Avatar
Hunter,DDS
Here is mine. I do rub at about 80% of full turn. Could be that I have brand new tires on it so the extra 15/32" of tire size is hurting me a little. My front leafs are wearing out though, so I have a set of X-codes for the front and B codes for the rear that will be going on this weekend
Old Feb 2, 2012 | 08:02 AM
JoeDirt68's Avatar
JoeDirt68
Here is mine with the 2011's
3.5" Fabtech lift no rubbing at all except me when I look at it!
I like a little squat with the camper on, it keeps the sway away.
Trailer is a 28' bunkhouse, about 8,000# loaded up
