Y style steering
Old Jan 31, 2012 | 09:05 PM
White76's Avatar
White76
Y style steering
Ok so I finally got my 6 inch lift in my truck and now the tires are both faceing inward. I was told that I wouldnt need a drop pitman arm but im thinking I do now?
1976 f150 ranger xlt
360 c6
Old Jan 31, 2012 | 09:20 PM
HIO Silver's Avatar
HIO Silver
Who told ya that one wasn't needed? I'd kick'em in the nards.
Yes, you need to get one and switch to the T-style steering. The lift has increased the relative distance btwn the steering box and the steering arm on the knuckle. I don't think there's enough adjustability in the tie rods to compensate.
Old Jan 31, 2012 | 09:48 PM
teds74ford's Avatar
teds74ford
You need to be careful when you use a drop pitman that the track bar angle is matched (with a drop bracket as well)
Moreover, on the older trucks, you need to upgrade to a setup like the 78-79s had when you install a lift kit. I personally used chevy TREs and DOM tubing, but a stock replacement for a 79 would work as well.
Old Feb 1, 2012 | 06:11 AM
White76's Avatar
White76
Is it possoble to use the old y style steering with a drop pitman arm until I have the funds for the new steering components
Old Feb 1, 2012 | 07:56 AM
Blown 331's Avatar
Blown 331
Nope. I have never seen a drop pitman for a 73-77 F-150 and a 78/79 pitman will not attach to the inverted Y steering.
Old Feb 1, 2012 | 12:26 PM
thekingofcows's Avatar
thekingofcows
Run like te wind from y style steering, If you want longevity out of your steering system, and if you want it to handle right. I have never had any luck whatsoever out of Y style steering in a lifted vehicle.
Also of you do upgrade to a better steering system, don't get a drop pitman arm that has a lot of drop. The more drop a pitman arm has the more strain it put on the box (sector shaft and bolts). Instead if you do the Chevy tre upgrade, get the 7.15* tapered reamer and flip the tre ends on top of the steering arm.
If you decide to go this route let us know and well try to supply pics and part numbers.
Old Feb 1, 2012 | 01:41 PM
White76's Avatar
White76
Thanks thekingofcows...What are the advantages to the cheby steering parts?
Old Feb 1, 2012 | 03:33 PM
Blown 331's Avatar
Blown 331
I'm still running the stock steering on my 77 F-150 but I got real lucky at a junkyard one day. There was a lifted 79 Bronco in the junkyard with a drop pitman arm. So I came back for that and the steering linkage. My pitman arm puller wasn't big enough so I just took the whole gear box too. lol. I got all of for less than half the price of just a drop pitman arm.
Old Feb 1, 2012 | 04:06 PM
thekingofcows
They are debatedbly stronger, and definitely larger. You can buy them at any parts store for cheap.
They are easy to adapt to these old fords.
The setup would look something like this.
Old Feb 1, 2012 | 08:53 PM
teds74ford's Avatar
teds74ford
Here's a writeup I did a few years ago that tells what parts I used and what exact issues I ran into.
https://www.ford-trucks.com/forums/7...ch-thread.html
Old Feb 2, 2012 | 05:41 AM
White76's Avatar
White76
Thanks, that looks doable and I'm going to look into it the parts this week.
Phildo
Apr 15, 2016 11:54 PM
Henrys son
Aug 29, 2008 10:59 AM
oneofakind97
Offroad & 4x4
Jun 13, 2008 07:01 PM
madon
Jul 23, 2003 10:06 AM
Fast Eddie
Offroad & 4x4
Oct 30, 2002 08:52 PM
