Speedometer proplem
Old Feb 11, 2012 | 07:10 AM
subford's Avatar
subford
Originally Posted by 86F150302
Yes shifting problems related to vss code. It's been to Ford, 2 trans shops, and another shop. Can't find what's causing it.
If the speedometer is working OK then try unplugging the Speed Control Module under the hood.
Other than that you need to put a O-scope on the signal from the rear end with the wheels off the ground and on jack stands. It could also be the VSS gap or bad wiring.
You may also want to read the pdf below:
http://www.wellsve.com/sft503/Counterpoint4_2.pdf
Old Feb 11, 2012 | 08:06 AM
86F150302's Avatar
86F150302
I have unplugged both. No changes. I do have an o scope. Just gotta figure out how to use it. Lol. Guess ill have to try that next. Thank you.
Old Feb 11, 2012 | 09:37 AM
444dieselrod's Avatar
444dieselrod
My '97 was giving me problems like that. Abs light would come on, od off light would flash and it shifted like crap. Turned out it was the plug for the tail lights above the bumper. The plug slowly filled up with road grime and dust, the contacts finally got so dirty it wouldn't make good contact. Even with the lights off these trucks send a signal through the tail lights something about the converter unlock signal coming from the tail lights. I suggest pulling that plug apart and giving it a good blast of brake cleaner to shine it up.
Old Feb 11, 2012 | 10:00 AM
subford's Avatar
subford
A shorted brake lamp wire to marker lamp wire or shorted bulb will disengage the TC clutch and turn off the speed control the same as stepping on the brake (BOO switch).
But I do not see how it would flash the OD lamp or the RABS lamp or cause bad shifting.
It would be the same as riding the brakes with the brake lights on.
Old Feb 11, 2012 | 02:26 PM
444dieselrod
All I can tell ya is it was in the plug. I could tell the second I started it, the abs light would be on and the od light was flashing. So I had to reach in and wiggle that plug then it would go out and shift fine.
Old Feb 11, 2012 | 02:30 PM
f-trucker88's Avatar
f-trucker88
i have a similar problem i have a 89 f150 and the spedo quit working for me i took the gear out of the tranfer case it doesnt apear to be damaged and i havnt been able to turn the cable inner portion and look at the speedo at the same time to confirm oporation is there any other tricks you guys would suggest for checking this?
Old Feb 11, 2012 | 03:36 PM
88n94's Avatar
88n94
Get an assistant to watch the speedometer while you turn the gear. Probably your speedometer cable is broken or more likely the gear inside the transfer case is worn down. By testing this you will know which way to go. Make sure you turn the gear the correct direction when you have your assistant watch the speedometer. I think you would need to go counterclockwise.
Old Feb 11, 2012 | 04:37 PM
f-trucker88
yes thats the hard part the assistant!!! lol but ill do that
Old Feb 11, 2012 | 05:37 PM
Eddiec1564's Avatar
Eddiec1564
While we are on wierd PSOM problems.... I got one now with my 95 E350. Its the same setup as the F-series so all problems would be the same between them.
Few years ago I had the capacitor leak acid out on the PSOM circut board and caused the OD to flash and hard shifting tranny, cruse not working. I got that all fixed till now. I have keeped track of my MPG and noticed a drop for the last few fill ups. Normally that bus gives 8.5 MPG now its 6 mpg and dropping! What I found out was the PSOM is not saving the mileage into the EEPROM!! Any thoughs about this? Speed and miles are good till you turn off the ignition so the calibrations are good.
I can give this suggestion to the OP about his issue. Even though you replaced the PSOM, VSS ect. Check that bulkhead connector on the firewall. I had seen few problems with that connector not making a good contact. I found one on my 89 F250 today which was causing a cruse control issue on it.
Old Feb 11, 2012 | 07:10 PM
subford's Avatar
subford
If the PSOM is not saving the mileage into the EEPROM it would have to be a bad PSOM.
JimWithAnOBS
21
May 26, 2018 10:42 AM
juiceymustang
20
Jul 15, 2014 03:30 PM
Mike3425
Nov 16, 2006 06:16 PM
F2504x4
Aug 1, 2005 08:44 PM
rzq4x4
Jun 18, 2005 03:40 AM
