VSS Sensor
Old Nov 16, 2006 | 06:15 PM
Mike3425's Avatar
Mike3425
VSS Sensor
92,F150,4x4. The speedometer is not working and the transmission is shifting very hard. Code pulled said no signal from VSS. Bought a new VSS and cannot find where it mounts. The trans code is E. Number on tag on transfer case is F2TAAB. Anyone know where the VSS is located or do I have the wrong part? Code pulled was 452 o,c,r. Thanks
Old Nov 16, 2006 | 06:16 PM
andym's Avatar
andym
The VSS is on top of the rear axle. It has two wires going to it. If that doesn't fix the problem, then it could be the wiring to the VSS or the speedo itself.
