which hubs do I have? (spline count) 92 F250
I just bought a 92 F250 4x4 (extra cab, 351 5 spd standard) which has automatic hubs and I would like to replace them with manual hubs. I see Warn has 2 models, one for 19 spline and one for 30 spline axles. Is there an easy way to tell which I have without taking anything apart?
Thanks in advance!
Thanks in advance!
photos of hub and front diff
based on the fact the hub cap holes are much larger than the hubs themselves and what bashby said and the fact these hubs look about the same size as the ones I had on my 73 bronco (dana 44) I am guessing I have a light duty front diff that would take the Warn 9790 hubs as opposed to the heavy duty P/N 11690 hubs.
Does that seem like the case? Thanks
thanks Andy
thanks for the quick reply Andy!
so if it is a dana 50 do you know if that means I need the "heavy duty" version of the Warn hubs?
(from the Warn site application table: Warn Industries - 4WD Standard Manual Hubs)
3/4 Ton Pickup, Light Duty '77.5-97 H 19 spline PN 9790
3/4 Ton Pickup, Heavy Duty '78-97 H 30 spline PN 11690
Hey edbee, all extended cab and crew cab F250s are heavy duty with full floating rear axles. Regular cab F250s can be light(semi floating rear axle) or heavy duty(full floating rear axle)IIRC. So that being the case and you have an extended cab you have a heavy duty (8800 lbs gvwr (off door sticker)).
Thx
Ken
Thx
Ken
ola1234
10-17-2007 08:40 PM
Brett73-79
11-14-2006 09:56 AM
