Fuel Injectors
Old Jan 31, 2012 | 02:50 PM
Pickupman2004's Avatar
Pickupman2004
Fuel Injectors
Might have a fuel injector issue. If that turns out to be the case, was curious what injectors would be used for replacement?.....Ford refurbished injectors? or something different?
Also, does replacing injectors involve head gaskets? was wondering if it made sense to install head bolts at the same time.
Old Jan 31, 2012 | 04:30 PM
npccpartsman's Avatar
npccpartsman
Motorcraft injectors are your best value IMHO. You can find them for $200-220 plus core. No gaskets required at all to do injectors. The valve cover gasket is reusable and Motorcraft injectors come with all the sealing rings installed.
dwdranch
May 15, 2013 07:24 AM
ecsmith0624
1978 - 1996 Big Bronco
Nov 21, 2003 07:51 PM
CrazyFordMan
Sep 24, 2003 11:59 PM
atving2
Apr 9, 2003 10:17 PM
