Trans. Issues (Clatter)
Old Jan 31, 2012 | 11:38 AM
03_PSD's Avatar
03_PSD
Is this a bad throwout bearing??? - YouTube
I know its a dodge but mines makeing an awful sound when I push in the clutch like shown in the video. Any ideas. Truck drives and shifts fine, I can't make the clutch slip at all. I don't want to keep driving it and tear something up.
Old Jan 31, 2012 | 11:48 AM
nlemerise's Avatar
nlemerise
Sounds like the throw-out bearing is toast...
Old Jan 31, 2012 | 11:54 AM
03_PSD's Avatar
03_PSD
Should I park it until its fixed or can I limp around momentarily? How hard is this to fix and are there any updated parts?
Old Jan 31, 2012 | 12:28 PM
nlemerise's Avatar
nlemerise
IF it is the throw-out bearing (I would certainly gain others expertise on the subject) you can drive it until the bearing seizes or shatters. I once drove a truck from Iowa to California without a clutch, but it wasn't any fun! IF it is the throw-out bearing, you will need to drop the tranny to replace the bearing...at that point I would replace the clutch and pressure plate, and update the clutch fork (this is an updated part) for the clutch pedal. Here is a link to Kwik's job...
Old Jan 31, 2012 | 05:00 PM
03_PSD's Avatar
03_PSD
Well it took a turn for the worse, I could barely get it into gear from a stop heading home. Time for a clutch, thinking valair. Any thoughts
GravyCrockett
Feb 8, 2018 01:14 PM
wils3825
Mar 17, 2015 11:40 AM
Jespo80f150
Jul 11, 2012 04:04 PM
toddol1971
May 9, 2007 08:29 AM
skeneguy
Oct 14, 2004 08:39 PM
