inline 6
Old Jan 31, 2012 | 03:33 AM
4294vgashole's Avatar
4294vgashole
inline 6
72 f250
wanna yank the 390 and put in a rebuilt inline 6 I got
already know the existing c6 wont bolt up
how do I go about finding a c6 that will?
Also gas tank behing seat is rusted and leaking.
Any aftermarkets available?
Or whats the best way to seal it?
Old Jan 31, 2012 | 08:20 AM
tmcalavy's Avatar
tmcalavy
You need a small bellhousing C6 or a C4 for your I-6...check the classifieds here, on fordification.com, and your local online sites like Craigslist. Also check local pick-n-pull yards. Both are out there, you just have to look for a while to find what you want/need. If your tank is that rusted, I would pull it and trash it. Replace it with a better tank from a pick-n-pull yard...some folks don't like the in-cab tank, so they pull it and install a mustang or other tank between the frame rails back where the spare tire goes. That requires some modification however.
Old Jan 31, 2012 | 11:27 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by 4294vgashole
72 f250 wanna yank the 390 and put in a rebuilt inline 6 I got already know the existing c6 wont bolt up how do I go about finding a c6 that will?
Also gas tank behing seat is rusted and leaking. Any aftermarkets available?
C6 first offered with 300 I-6 in 1978 as an option, so some will still have a C4.
19.5 gallon in-cab fuel tank reproduced by FTE sponsor Blue Oval Truck Parts (Anaheim CA), available from all the repro parts sellers.
Fits: 1961/66 F100/800 / 1967/72 F100/750.
Old Jan 31, 2012 | 03:25 PM
RichS2659's Avatar
RichS2659
The 300 uses the same bellhousing as the smallblock V-8 (302/351W). Check for a C-6 in vans also. Is your C-6 in good shape or does it need rebuilt? You could find a good small block C-6 case and swap your FE internals for the small block case.
Larry5501
Dec 23, 2017 10:02 AM
Ford Tempo Fan
Jul 19, 2015 10:40 PM
kentruckf100
Oct 1, 2014 08:58 AM
CT
Jul 4, 1999 12:54 PM
