6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
another problem...
Old Jan 30, 2012 | 11:31 PM
rbblaylock's Avatar
rbblaylock
another problem...
hey guys, for those that dont remember my previous post, had a complete fuel system replacement and oil cooler replacement last week
Just got the truck back and it had a faint squeal when i got on the gas hard after it was warmed up...called dealer and was able to stop by a few hours later, we couldnt get the squeal back
had the truck for a week, no problems, hooked up to my 32' enclosed, 10klbs loaded, truck got the squeal on hard acceleration, noticed high sustained turbo psi (30 while rpms were around 1300, 50mph no hills/wind)
talked to a freightliner mechanic while i was swapping trailer (same size and load) and he said the turbo hose may have a pin hole, should just expect crappy performance.
On the way back, turbo was almost pegged on 30, low rpms, low throttle imput, gas mileage was at 6.7 when was at 9+ the way down
had 2 DPF cleans on the way down, 9....yes 9! on the way back up!
What should i expect from the dealer tomorrow?
edit** this was a 3hr trip one way, flat coastal land, no wind/traffic, open highway for 98% of the trip
Old Jan 30, 2012 | 11:59 PM
RM2738's Avatar
RM2738
Typically, if they can't recreate the problem, they'll send you packing.
Old Jan 31, 2012 | 05:14 AM
senix's Avatar
senix
inspect all the boots your self for a loose clamp. Also report the very poor ecomony and overboosting to them.
Since it was sitting for awhile maybe that has something to do with it too.
The squeal....is that more of a whistle?
Old Jan 31, 2012 | 10:16 AM
rbblaylock's Avatar
rbblaylock
checked all i really could and cant find anything obvious to me anyway
it was first a squeal, almost like a belt...but not, on acceleration, would last for about 200rpm
after we got off the freeway and started through the neighborhood, it was a pretty constant, just just on acceleration but cruising at 30-40mph had it
i say squeal because it sounded like it had friction involved with it, if that makes any sense. it just didnt sound like air alone. I tried taking a video with my phone but it would really show up
Old Jan 31, 2012 | 12:25 PM
rbblaylock's Avatar
rbblaylock
Turbo issue - YouTube
Best I could get
Old Jan 31, 2012 | 09:28 PM
RM2738's Avatar
RM2738
Best I could get
Right in the 3-4 second mark you can faintly hear it. Sound like something slipping almost.
Old Jan 31, 2012 | 10:17 PM
tgreening's Avatar
tgreening
Sometimes an alternator will give a squeal like that when it's starting to head south. Something else to consider.
Old Feb 1, 2012 | 05:02 AM
senix's Avatar
senix
that sounds to like belt or idler arm pully squeal.
They won't replace unless they can duplicate that. You are gonna have to wait till it is more consistent if you ask me.
Old Feb 3, 2012 | 12:42 PM
rbblaylock's Avatar
rbblaylock
just got back from a test drive, tech said he thinks the exhaust is cracked before the dpf and the turbo is lacking back pressure? how could that be if many of you remove the dpf unless the tuner programs it for less pressure???
anyway, he said he feels its that because the avg mpg (which i never have up because its depressing) was reading 24 steady at 45mpg, reset it and was at 18mpg at 70! he said the exhaust is pretty much open from the downpipe back and bypassing the dpf/cat
regardless, he wasnt sure and needed to do a smoke test, they were pretty backed up and im on call this weekend, so i wasnt able to leave it. Will have to be on monday...guess ill suffer with more mpgs
cricci121
Dec 23, 2010 06:25 PM
onirot
Jul 24, 2007 01:07 AM
NewFordOwner
May 26, 2005 02:38 PM
Saxon
Apr 25, 2005 11:36 PM
TurboTuff
Dec 22, 2002 04:08 PM
