Fuel Delivery Problem
Old Feb 2, 2012 | 03:33 PM
hawgystyle's Avatar
hawgystyle
Spoke too soon, still have the problem.
Old Feb 2, 2012 | 03:36 PM
hawgystyle's Avatar
hawgystyle
Removed the fuel cap to test the tank breathers and that didnt help. Took the two hoses off the tank and stuck them in a bucket again and no problems. Has to be the pick up. I can come to anything else. Anyone know where i can get a new one?
Old Feb 2, 2012 | 05:10 PM
cj06's Avatar
cj06
pull the sending units out and if nothing else you can solder new tubes on , or stick a piece of fuel line over the old tubes !
Old Feb 2, 2012 | 06:32 PM
bashby's Avatar
bashby
I used a brass compression union and a short piece of 3/8 steel line on dad's 96 F350. It has worked fine so far.
Old Feb 3, 2012 | 07:34 AM
hawgystyle's Avatar
hawgystyle
My plan is to cut the pick up tube off and drill it out and put a longer fuel line into the tank and set it just off the bottom with a screen on it. any pros/cons?
Old Feb 3, 2012 | 06:03 PM
bashby's Avatar
bashby
Not sure what you mean by cut it off and drill it out.
filadog23c
Nov 6, 2019 10:45 AM
75dually
May 10, 2012 03:21 AM
thebig350
Dec 28, 2010 08:22 PM
paddler
Apr 6, 2009 03:04 PM
dkrahn
May 26, 2007 09:04 PM
