current lift?
Old Jan 29, 2012 | 11:21 AM
1978-BBB's Avatar
1978-BBB
current lift?
so i've had my truck for a year or so and i kinda want to get it a little bit bigger. when i bought it i was told it has a 4" lift, but i honestly dont know, not much where i live to compare to. my question is by looking at the pic can you tell how much of a lift and also how big can i go with just changing springs and nothing else?
Old Jan 29, 2012 | 11:22 AM
1978-BBB's Avatar
1978-BBB
tires are BALD 36" swampers
Old Jan 29, 2012 | 11:24 AM
1978-BBB's Avatar
1978-BBB
Old Jan 29, 2012 | 05:54 PM
1978-BBB's Avatar
1978-BBB
anybody have a clue?
Old Jan 29, 2012 | 05:59 PM
JB78f150's Avatar
JB78f150
I'd say it looks stock.
Here's mine with 285's with 2 inch blocks in the back.
Old Jan 29, 2012 | 06:01 PM
ogreyghost's Avatar
ogreyghost
maybe a 4" check for blocks under springs hopefully u dont have that. You will also have to replace shocks for longer ones and probably get a dropped pitman arm to correct steering angle in order to do it right
Old Jan 29, 2012 | 06:07 PM
1978-BBB's Avatar
1978-BBB
there are blocks in the back, cant remeber what i measured but it wasent 4" for sure ( would the block basically mean thats how big lift it? ), shocks i know will be fine they are too big for truck as is. i did get a 2.5" drop drag link too becasue the old drag link was dangerously worn.
Old Jan 29, 2012 | 06:11 PM
JB78f150's Avatar
JB78f150
Should be 4 inch blocks in there from the factory. If they have a tab coming off of them going towards the diff then they are factory.
Old Jan 29, 2012 | 06:15 PM
1978-BBB's Avatar
1978-BBB
they do have that tab coming off of them, so is that to say that the truck isnt lifted? or P/O changed springs only?
Old Jan 29, 2012 | 06:18 PM
JB78f150's Avatar
JB78f150
I think he thought he had a highboy but he didn't. I don't see anything to tell me it was lifted.
Old Jan 29, 2012 | 06:19 PM
JB78f150's Avatar
JB78f150
Got some closer pictures? one of the leafs, on each corner would be great.
Old Jan 29, 2012 | 06:24 PM
1978-BBB's Avatar
1978-BBB
not best pic but you can see the small block.
Old Jan 29, 2012 | 06:25 PM
JB78f150's Avatar
JB78f150
That's all stock. If it was lift springs than they would have more arch.
Old Jan 29, 2012 | 06:27 PM
ManfredVonRichtofen's Avatar
ManfredVonRichtofen
You have what my 79 has..and I have 38s on mine...it comes close to my front fendrs.
Old Jan 29, 2012 | 06:32 PM
1978-BBB's Avatar
1978-BBB
yeah i figured there wasent really any arch so there wasent much if any lift. i have 35" BFG all terrains now but i want more height. i know the back shocks are fine front ones should be good for a little height, so i guess besides drop drag link what else would i need to gett it a bit higher? minus the obvious leafs.
