current lift?
Old Feb 1, 2012 | 08:59 PM
  #31
twinzilla's Avatar
twinzilla
Looks like a 4" lift to me..leafs in the front of a stock 78 almost have a negative arch, your leafs have a positive arch in the pics.
Old Feb 1, 2012 | 09:09 PM
  #32
ford141's Avatar
ford141
That looks like stock front leafs to me with an add-a-leaf. It's probably 2" over stock. You can tell the add-a-leaf by the curve at the end of the bottom leaf as opposed to the two flat stock leafs.
Old Feb 1, 2012 | 09:48 PM
  #33
1978-BBB's Avatar
1978-BBB
so we say i have between a 2" and 4" lift possibly. i appreciate the comments guys, i would never know the difference b/c this is my first truck.
Old Feb 1, 2012 | 10:00 PM
  #34
twinzilla's Avatar
twinzilla
I'm still thinking you have aftermarket front leafs netting you about 4" of lift. I don't think you'd get the 36" swampers under it w/just 2" add-a-leafs.
Old Feb 1, 2012 | 10:52 PM
  #35
1978-BBB's Avatar
1978-BBB
so lets say i have 4" in the front what does that say about the rear b/c my pics match other peoples rear and they are stock, would a 4" make the truck level? or would you say back leafs have been done too?
Old Feb 2, 2012 | 04:11 AM
  #36
twinzilla's Avatar
twinzilla
Rear springs/blocks look stock, so yes the front lift may have just leveled it out. From what I've seen these trucks (78/9's) do somewhat of a nose-dive from the factory.
Old Feb 2, 2012 | 07:13 AM
  #37
ford141's Avatar
ford141
I had 36s under my truck with no lift.
Typically 4" aftermarket leafs are multi-leaf pack with 4-5 leafs, each leaf being smaller than the one above it. That looks to me like a stock 2-leaf pack with one additional leaf pulled from a rear leaf spring pack. Look at the leaf spring clamp on the bottom leaf. See how long it is? That is because it is designed to clamp a much thicker leaf spring pack, like a rear pack. Rear packs also have more of a curve, which explains why the bottom leaf is curve more than the other 2 leaves.
Old Feb 2, 2012 | 07:35 AM
  #38
twinzilla's Avatar
twinzilla
Yeh could be, like I said it looks like around 4" to me because of the stance & distance between the 36's & fender wells. There's no way I could get 36's under my 78 Snowfighter F250, or my old 79 F350 without a lift. Maybe the front leafs were re-arched with an add-a-leaf, idk?
Old Feb 2, 2012 | 12:04 PM
  #39
1978-BBB's Avatar
1978-BBB
ok so all that being said, can i get anymore height with having to change alot of other stuff? i know my shocks are big enough for a bit more ( they are kinda too big as is ) and i do have a 2.5" drop drag link.
Old Feb 2, 2012 | 03:09 PM
  #40
ford141's Avatar
ford141
You can probably go another 2-3 inches without many problems as long as you use a dropped pitman arm. A dropped drag link will help with drag link end angles, but won't do anything for bump steer. Going with a dropped pitman arm would be better (keeps the drag link closer to parallel with the ground. Any more that 4" of lift over stock requires crossover steering to minimize bump steer. Any more than 6" over stock requires drive shaft mods.
Old Feb 2, 2012 | 03:22 PM
  #41
montana_highboy's Avatar
montana_highboy
Originally Posted by 1978-BBB
Looks like you have 2" lift springs with an add-a-leaf, netting you around 3-4" of lift, stock 78/79 springs are flat, with i slight negative arch.
Old Feb 2, 2012 | 03:48 PM
  #42
NW 150's Avatar
NW 150
That looks to be about a 4" lift if you ask me. 36s? 35's are tight with no lift from what everyone else says on here. Look for the leaf springs that aren't chamfered at the ends, those aren't stock. Those are the add-a-leafs for my trucks.
Just noticed your truck is a 250, could be less than 4" then but I'd still say that there's some lift.
Old Feb 2, 2012 | 06:16 PM
  #43
1978-BBB's Avatar
1978-BBB
yeah in thought the one leaf up front looked a little "non stock". well looks like i have figured out what i got now i gotta get the money to makeit bigger haha, thanks tio all you guys who had some input
Old Feb 2, 2012 | 07:35 PM
  #44
NW 150's Avatar
NW 150
no prob, another 2-3" or so with 36s-37s and that thing will sit perfect IMO.
Old Feb 2, 2012 | 09:05 PM
  #45
1978-BBB's Avatar
1978-BBB
thats kinda what i want is 2-3 more and have proper room fro 35's/36's. right now i jsut feel it could that much higher and look that much better.
toyowarrior
6.7L Power Stroke Diesel
94
Mar 18, 2022 05:02 PM
bagman1995
Mar 23, 2018 06:28 PM
GuitarJesus
May 15, 2017 06:04 PM
19mfn96
Jan 30, 2012 09:13 PM
jc8825
Dec 7, 2011 05:43 AM
