Sponsored by: Real Truck
? Something pulling it down ?
Old Jan 28, 2012 | 03:37 PM
usmctadpole's Avatar
usmctadpole
1. ok I got an 05 F250 xl 5.4 I really need the fuse box diagram because my truck did not come with any of the paper work.
2. I have installed a cb and 4 off road lights on my truck everything is wired straigh to the battery with in line fuses. But for the past 2 weeks it has been dead over night. I had battery and all check out they say there good, but battery is 7 years old motorcraft. So im sure my lights and cb are more than likely pulling it down, But I just dont know what to do from here. Any ideas? Thanks for the help!
Old Jan 28, 2012 | 06:42 PM
redford's Avatar
redford
FTE Leadership Emeritus
You can download a free PDF copy of your owners manual here.
http://www.motorcraftservice.com/vdi...S-EN&YEAR=2005
Old Jan 28, 2012 | 07:03 PM
usmctadpole
Thanks for that. Any ideas on the problem I'm having?
Old Jan 28, 2012 | 07:15 PM
Rongold's Avatar
Rongold
Disconnect the battery when you park the truck for the night. Reconnect it in the AM. If it's dead, then it's dying all by itself. I really would not trust a 7 year old battery, regardless of how it tests.
RON
Old Jan 28, 2012 | 07:26 PM
redford's Avatar
redford
BTW, thank you for your service USMCtadpole.
Old Jan 28, 2012 | 07:45 PM
usmctadpole
Anything for the country. Ron that's great common since right there. I will try that.
Old Jan 28, 2012 | 08:32 PM
BareBones's Avatar
BareBones
Agreed on the battery. Seven years is reason enough to replace it all by itself....
Old Jan 29, 2012 | 10:15 PM
usmctadpole
Ok so after I unhooked everything and truck has been sitting for 24 hrs. My battery has not died yet. But it has been taking a few days to happen. So I'm going to get a new one this week anyway. But if it is my lights, how should I wire them to only draw power when truck is on. Any threads on this?
Old Jan 30, 2012 | 11:23 AM
SuperDutyScaler's Avatar
SuperDutyScaler
do you have switches for them? I assume you do have switches so as long as you have the switches off it will not draw any power
Old Jan 30, 2012 | 12:22 PM
usmctadpole
Yea they are on switches put I know it pulls power to the switch and then stops there till I turn them on. Thats not gonna draw the battery down enough to hurt anything right? I got a new battery today and truck is cranking faster than ever and RPMs are not dieing at idle. So I got it fixed.
RevLemmon
Aug 23, 2014 12:05 PM
MyName1sMud
39
May 11, 2012 09:41 PM
Alphabitch
Electrical Systems/Wiring
Aug 10, 2009 08:28 AM
imafordboi69
Sep 8, 2008 04:39 PM
ktplotts
Feb 23, 2005 07:29 PM
