Sponsored by: Real Truck
which battery?
Old Feb 21, 2005 | 06:50 PM
ktplotts's Avatar
ktplotts
which battery?
I'm getting ready to hook up some driving lights and aux. lights to my truck and wanted to know if it makes a difference on what battery to hook up too. I also have dual alternators, if that changes anything.
Thanks,
-Kevin
05 F-350 CC 6.0L Lariet
Old Feb 21, 2005 | 07:20 PM
high ho silver's Avatar
high ho silver
Why would you want to hook up to the battery when the underdash Ford fuse panel gives you hot connection points that are empty and ready for your extra stuff?
Old Feb 22, 2005 | 06:19 PM
NiNjA DoC's Avatar
NiNjA DoC
which ones? are they numbered or labled?
Old Feb 22, 2005 | 07:59 PM
ktplotts's Avatar
ktplotts
because in my situation it is easier to hook up to the battery. The factory fuse block is probably nice for some stuff, but not for what i need.
-Kevin
Old Feb 22, 2005 | 11:39 PM
vlietracer64's Avatar
vlietracer64
It dose not matter which battery you decide to hook up to, which ever one is more convienent for you, They are both joined together in a parallel connection.
Old Feb 23, 2005 | 07:29 PM
high ho silver
Smile
Look in your manual, it will tell you which are not used. You will need to use a light tester to find one that is only hot with the ignition switch.
