Sponsored by: Real Truck
Fan in engine compartment question.
Old Jan 28, 2012 | 10:06 AM
Bender24's Avatar
Bender24
This happened for the first time yesterday. Driving down the highway and "a" fan came on in the engine compartment. It is really loud sounds like a huge blower. The engine temp is normal. The degas bottle is at the proper level. No check engine or wrench lights. It will run even in town doing 15-20 mph. It will shut off for a bit then engage again. Curious what is going on.
Old Jan 28, 2012 | 10:37 AM
Lazy K's Avatar
Lazy K
I would think it is the engine cooling fan clutch engaging and operating as it should.
Old Jan 28, 2012 | 10:46 AM
PA-Mark's Avatar
PA-Mark
the fan will make quite a bit of noise like you described, and turn on and off during normal engine temps, but why you have never heard it operate before is my question to you. how long have you had this vechicle? If it is different from normal then you may have a problem, but if this is a relitively knew to you truck, and your just not used to it than it is most likely normal.
Old Jan 28, 2012 | 11:56 AM
Bigpipes 35's Avatar
Bigpipes 35
we need to know more info on the truck such as year , engine ect..
Bender24
6.4L Power Stroke Diesel
Jan 28, 2012 11:35 AM
04scurs
Jul 29, 2010 09:38 AM
dieself250
Oct 24, 2005 09:46 PM
mjbesen310
2004 - 2008 F150
Feb 7, 2005 05:28 AM
