return line problems
Old Jan 28, 2012 | 03:27 AM
79fordf250pickup's Avatar
79fordf250pickup
i just put all new o rings and return lines on and its still leaking under the caps really bad. what do i do now? and every time i shut my truck off it wont turn over again, 2 brand new batteries and alternator tests good.
Old Jan 28, 2012 | 04:08 AM
Jayme Duty's Avatar
Jayme Duty
have your starter tested, My old 91 did that a couple years ago. I replaced both batteries and still no turning over. had the starter tested and bam.
Old Jan 28, 2012 | 08:36 AM
turtlemann14's Avatar
turtlemann14
if i remember right, we had a few o rings roll out of the groove when we put them on
Old Jan 28, 2012 | 08:57 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT
you probably didn't use petroleum jelly on the new O-rings,and they got nicked during install.the only thing to do now,is to pull them,install new O-rings lubed up good this time,and reinstall.
first you can double check that you pushed down on the caps firmly enough.you sometimes feel and or hear them "snap"
don't be afraid to use some pressure to make it happen.the steel FI lines don't hold the caps.only the O-rings do.
as for the last part;
some people confuse "turning over" with "firing".
does the engine spin and just doesn't want to start (explained by leaking caps) or is it really not turning over at all? (an separate issue.)
Old Jan 28, 2012 | 09:55 AM
79fordf250pickup
ok ill put new o rings on, and it turns over very slowly, then i put the jump box on it and it fires right up.
Old Jan 28, 2012 | 12:35 PM
tecgod13's Avatar
tecgod13
That sounds like dead batteries. How did you check the alternator? Are you sure its actually charging the batteries?
What condition are the battery cables in? Check the connections at both ends to make sure they corroded. If the ends of the cables are swollen, the cables themselves could be going bad.
Old Jan 30, 2012 | 09:28 PM
79fordf250pickup
i got it figured out i out thicker o rings on and the alternator was not grounded.
thanks guys
Old Jan 30, 2012 | 10:23 PM
tecgod13's Avatar
tecgod13
Alternator should have been grounded through the mounting.
But let us know in a few days if its all good.
6.9lbluenose
Jun 9, 2019 07:48 AM
Ineedhelpfastsoicang
Apr 14, 2016 09:01 PM
Totally Tuna
Jul 16, 2007 07:02 PM
catbird7
Jun 26, 2006 11:35 PM
cuttressb
Apr 26, 2006 04:55 AM
