no throttle respose
Old Jan 29, 2012 | 07:09 PM
fordpride's Avatar
fordpride
I had two dorman ones and they didn't last six months
Old Jan 30, 2012 | 11:15 AM
Desert Rancher's Avatar
Desert Rancher
Originally Posted by bubba_3711
its possable they gave you the wrong tps, thats what happened with mine, i replaced mine it didnt work, it looked just a little different on the inside where it controles how much throttle you give it. so i went back they wouldnt return it, made me mad so i wet to the junk yard and i got one from there and the junk yard oe worked just fine.
There is a TPS for the SD. It will not work for an OBS.
~DR
Old Jan 30, 2012 | 06:50 PM
bowmansreptiles's Avatar
bowmansreptiles
Well I checked the switch with an ohm meter and opens and closes just fine, the tps that I got was for a 98 e350 so that might be y, the one it shows for my truck isn't the one that goes on it. It's a female plug and mines a male plug.
Old Jan 30, 2012 | 07:45 PM
fordpride's Avatar
fordpride
Click on the blue
Dorman OE Solutions 699-200 - Accelerator Pedal Sensor | O'Reilly Auto Parts
Old Jan 31, 2012 | 06:29 PM
bowmansreptiles
Thanks guys for all the help, it ended up being a rat/squirrel chewed thru some wires in the engine bay
Old Jan 31, 2012 | 08:04 PM
jiveturkey692000's Avatar
jiveturkey692000
What a little ***** lol! My dad had a ground hog chew through the fuel lines under his cadillac. Put it on the lift and there were bite marks all over the underside. Apparently It liked the taste of undercoating lol.
Old Jan 31, 2012 | 08:06 PM
fordpride's Avatar
fordpride
Man that sucks atleast it didn't fry anything
Old Jan 31, 2012 | 08:09 PM
bowmansreptiles
Yeh tell me about it. I felt like a retard when I saw it. I've been checking all on the inside the whole time.
Old Jan 31, 2012 | 08:13 PM
fordpride's Avatar
fordpride
I would disconnect the batteries ASAP
Old Jan 31, 2012 | 08:15 PM
bowmansreptiles
I did, I've already fixed it. Had to splice all the wires that were chewed thru and then it worked!
Old Feb 1, 2012 | 06:47 AM
DIYMechanic's Avatar
DIYMechanic
Sounds like you need one of your reptiles to live under the hood for a while, lol.
Old Feb 1, 2012 | 11:19 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
Originally Posted by MikeFromShiloh
it is just a small limit switch. use a multi meter and check it, is it opening / closing when you press / release the pedal? if not, pull the switch off and check it again. if not, replace it. if it is, then you may have to adjust the little tabs that triggers the switch.
JFYI here is a very good write up about the pedal:
https://www.ford-trucks.com/forums/1...-makomark.html
Old Feb 1, 2012 | 11:20 AM
  #28
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Talking
That was a good one
Glad you found and fixed your problem.
Old Feb 1, 2012 | 12:27 PM
  #29
madpogue's Avatar
madpogue
^^^^^^^ Next time a snake molts, wrap the skin around the wiring harness; that should warn off the rodents..... (Hmm, I see an aftermarket here......)
Old Feb 1, 2012 | 12:42 PM
  #30
DIYMechanic
Call it all natural wire loom...
Pockets52
6.4L Power Stroke Diesel
Mar 29, 2013 08:25 PM
joeyd61
Mar 5, 2013 02:18 PM
Hillbillyhotrod
Mar 30, 2010 11:12 AM
Torvvald
Mar 10, 2007 06:52 AM
kjswensen
Nov 4, 2006 01:26 PM
