Oil filter leak
Old Feb 1, 2012 | 11:54 AM
DanS12's Avatar
DanS12
Oil filter leak
Seems like every oil filter I put on my truck leaks.
Just a little bit, but really pisses me off. I guess I should of looked where the seal meets metal to see if I have a nick before I put the last one on.
Anyone else have this problem?
Old Feb 1, 2012 | 11:56 AM
fordpride's Avatar
fordpride
You sure its not the oil cooler leaking and running down the filter
Old Feb 1, 2012 | 11:57 AM
ford390gashog's Avatar
ford390gashog
The oem filter uses a beveled gasket to prevent this. Have you tried the OEM FL1995 filter? You sure its not the oil cooler leaking instead?
Old Feb 1, 2012 | 12:00 PM
DanS12's Avatar
DanS12
I do have the 1995 filter on. It appears to be the filter but maybe it is coming from the oil cooler. I'll check it out.
Old Feb 1, 2012 | 12:13 PM
DanS12's Avatar
DanS12
Is sure is oily above the oil filter. ( And dirty.)
I also noticed it looks like it might be leaking where the tubing goes back into the oil pan. Where is the oil cooler?
Old Feb 1, 2012 | 12:46 PM
PowerstrokeRyan's Avatar
PowerstrokeRyan
It is probably the block gasket on the oil cooler. I had that same issue on my truck. I did a write up on the oil cooler as well as others. its not that hard to do, just time consuming. If your good with your hands you can have it done in a couple of hours. This link is too the rebuild thread.https://www.ford-trucks.com/forums/1...uild-pics.html If you have problems you can call or text me at 920-676-7395 if nobody can get to you on time on here.
05 f250 6 inch lift
Jul 19, 2019 04:21 PM
caverjoe
Dec 2, 2013 05:51 PM
cubman61
Modular V10 (6.8l)
25
Dec 6, 2012 11:55 AM
mattyg50
Dec 15, 2006 02:06 PM
