Sponsored by: Auxito
Knock when engine is cold
Old Jan 27, 2012 | 12:23 PM
bk2011's Avatar
bk2011
I have a 2000 Ford F-150 with the 5.4 L and when the engine is cold it will knock untill it gets good and warmed up just woundering what is wrong with it
Old Jan 27, 2012 | 02:06 PM
00GT's Avatar
00GT
It's a 5.4 thing...every 5.4 I have ever owned has done it. That's why I now have a 4.6
This is just my experience with them.
Your question will most likely spark a debate..
Old Jan 27, 2012 | 04:06 PM
Bluegrass 7's Avatar
Bluegrass 7
Often the 5.4 in around those years develope what is called piston slap.
The noise tends to sound a bit hollow.
The skirts of the of one or more pistons get some wear or motor was built a bit on the loose side for tolerences.
When cold, the circular demension shrinks allowing the piston to rock in the bore as it changes direction over top dead center.
Combustion pressure rocks the crown to one side causing the noise.
As the engine heats, the piston skirt expands taking up the excess clearence and quiets down along with oil getting in the area from running.
Usually does not cause any problerms other than the noise we don't like to hear.
Another source can be the timing chains and tensioner so it depends on where you hear the noise when cold.
If timing chain related then you can have an issue later on.
If the noise subsides then don't be to concerned.
Good luck.
Old Jan 28, 2012 | 10:58 AM
steve(ill)'s Avatar
steve(ill)
Bluegrass probably has it pegged, but monitor your antifreeze level in the tank. If the leve drops an inch in a month or so.. post again.
thunderbolt427
2004 - 2008 F150
Dec 8, 2016 12:45 PM
anorm74
Modular V8 (4.6L, 5.4L)
Jan 18, 2013 09:31 PM
khelms_98
Feb 15, 2006 09:01 PM
sillyp
Sep 16, 2004 06:05 PM
69-R20
1997 - 2003 F150
Apr 16, 2003 11:05 AM
