Clockwise vs Counterclockwise
Old Jan 26, 2012 | 01:53 PM
Wriz's Avatar
Wriz
Let me first say....Im a *******!
I put a new cap and rotor on the 4.9L today and out of habit, re-connected the cables to cap counterclockwise. I tried to start the engine, I heard a pop and smelled burnt "something". I realized my mistake and connected them properly. Now it wont start. Turns over great, but gives no effort of starting. Inside of cap in clean, rotor appears unaffected. Im guessing Im not getting spark to the cylinders.
What did I do?! Let the beatings begin.........
Old Jan 26, 2012 | 02:11 PM
AbandonedBronco's Avatar
AbandonedBronco
Is this the '84 Bronco specified under your name?
If so, does it still have the entire feedback carburetor (computer controlled) setup still installed?
Old Jan 26, 2012 | 02:37 PM
Wriz's Avatar
Wriz
It is the 84. I really dont know if its computer controlled or not. Im not too familiar with these motors!
Old Jan 26, 2012 | 03:15 PM
AbandonedBronco
Stock was the computer controlled feedback setup. However, a lot of people swap them out for the Duraspark II ignition. Just seeing what ignition system you currently have installed to help diagnose.
Quick way to tell is if there are solenoids on the carburetor, a plug in directly on the side of the distributor (not a wire with a plug on on the end), and a big CHUNK of wires going into the firewall and into the cab. It also has a small distributor cap.
A duraspark II distributor has a vacuum line running to it from the carburetor, and has a much larger cap. Plus, there's an ignition module screwed down to the driver's side wheel well.
Old Jan 26, 2012 | 03:19 PM
Wriz's Avatar
Wriz
OK, it must be computer controlled because there is no duraspark II ignition, and I have the solenoids on the side of the carb with the plug as you described.
Old Jan 26, 2012 | 04:49 PM
Wriz's Avatar
Wriz
Stand down! When the truck backfired, it must have pinned the choke valve shut allowing no air in. Once I popped it back open, it fired right up. Thanks!
Old Jan 26, 2012 | 04:51 PM
critterf1's Avatar
critterf1
Pull the plugs, I bet they're fouled.
Old Jan 26, 2012 | 04:55 PM
AbandonedBronco
Hah! I've had that happen to me before, but had forgotten about it. I was working on the ignition/coil at the time, so I figured it was completely ignition related. After a few hours of hair pulling, I found the choke 100% shut.
Opened it up 1/8" and VROOM.
I hadn't replied to your previous post yet because I was racking my brain trying to figure out what would be damaged by a spark plug firing in the wrong order.... Hadn't come up with anything yet.
Glad you figured it out.
Old Jan 27, 2012 | 08:11 AM
1983F1503004x4's Avatar
1983F1503004x4
That's happened to me too.
It'll make you wanna run over yourself. LOL.
Killer79
Sep 8, 2018 04:55 AM
TGH
1978 - 1996 Big Bronco
Jul 27, 2016 11:43 PM
acbrown41
Bronco II
Jan 7, 2013 12:33 AM
Woodsman_30350
Jun 22, 2004 09:15 AM
GregCS
Jul 5, 2000 09:52 PM
