HPOP Line fitting trouble
Old Jan 26, 2012 | 11:14 AM
BlueScab's Avatar
BlueScab
I installed my new t500 last weekend and everything went smoothly. Love the power it brought back to my truck. Driving home last night I got on the throttle a little bit and the front HPOP line fitting at the pump decided to disconnect its self. Could it just have been the fitting on the line was weak and the t500 finished it off? Or the fitting on the new pump is worn and not allowing a solid connection?
I can push the line back on to the pump fitting but it dosent connect at all and will slide right back off. I plan on ordering new lines from clay tonite but, should I check on getting new fittings for the pump to?
Sorry for the long post. Thanks for your time!
Old Jan 26, 2012 | 11:18 AM
F250_'s Avatar
F250_
Sounds like the fitting is required, too. If you have wear on the hose end, you probably have wear inside the fitting as well. There is a chance that orings would take care of it, but I would be safe and just replace the fittings and hose at the same time.
Old Jan 26, 2012 | 11:19 AM
riverrat41's Avatar
riverrat41
When I changed the orings in the lines on mine one of them was really hard to get disconnected.When it finally did there was some rust on the connector(i guess from giving it a bath from time to time)
Was the black plastic ring put back in place when you re-attached the hose?
Old Jan 26, 2012 | 11:20 AM
woodnthings's Avatar
woodnthings
Are you sure that the hose end coupling is fully engaging and sliding properly to lock? It has to slide towards the hose to lock properly.
Old Jan 26, 2012 | 11:25 AM
BlueScab's Avatar
BlueScab
Yes the ring will slide down, but its just like there is nothing there for it to grab on to. Thank you all so much for replying so quickly!
Old Jan 26, 2012 | 11:32 AM
woodnthings
Your fittings could be worn down. It could be the line is bad too. A new line is definetly in order. Clay should be able to get the fittings also.
Old Jan 26, 2012 | 11:33 AM
F250_'s Avatar
F250_
If Clay doesn't have the fittings, Bob certainly does at DieselOrings.
Old Jan 26, 2012 | 11:36 AM
BlueScab's Avatar
BlueScab
Ok thanks guys!
woodnthings
Here is a recent post with similar information for you!
https://www.ford-trucks.com/forums/1...l#post11336134
Old Jan 26, 2012 | 11:40 AM
BlueScab's Avatar
BlueScab
I can't believe I didn't see that!
Old Jan 26, 2012 | 12:05 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Here you go, pump fittings and lines.
Riffraff Diesel Performance Parts: - HPOP Lines
Riffraff Diesel: Ford HPOP Outlet Hose Fitting
Old Jan 26, 2012 | 12:12 PM
BlueScab's Avatar
BlueScab
Thanks Clay! I'll be ordering them tonite or tomorrow morning along with some other "stuff" Lol.
A/Ox4
Oct 12, 2013 01:22 AM
Zorfox
Sep 25, 2010 05:40 PM
PAUL351W
Mar 31, 2006 12:51 AM
75Highboy460
Jan 24, 2006 09:33 PM
boflaade
Dec 6, 2003 10:47 AM
