Power Steering Return Line
Old Jan 23, 2006 | 03:44 PM
75Highboy460's Avatar
75Highboy460
I have found a replacement return line for my truck(75 4x4) at LMC. Looks like it is the same as what is on it now, basically a section of hose with a couple of clamps on it.
Has anyone found some place to buy a complete hose from the Bendix valve to the pump that does not include clamps? Seems like this will just start leaking again eventually.
Noel
Old Jan 23, 2006 | 04:30 PM
yield2s's Avatar
yield2s
I know what you're saying about the clamps eventually leaking but it dosnt happen untill the rubber gets so old and hard that it wont seal around the metal tubes, probably 20-30 years.
I had the same persistant leak on the return line and thought i could just cut off the end and reclamp it but even with multiple clamps it would leak.
The fix was a new piece of rubber hose, real simple.
Old Jan 23, 2006 | 04:46 PM
thelonerangerxlt's Avatar
thelonerangerxlt
There's much less pressure on the return hose than on the pressure side, so a clamp will hold fine. If you still want a 'stock' type hose, you might try NAPA. I've had good luck in getting (cough) Jeep hoses from them.
Old Jan 23, 2006 | 07:02 PM
ford390gashog's Avatar
ford390gashog
most never had anything more than a piece of 3/8'' fuel line and 2 clamps from factory.
Old Jan 23, 2006 | 09:12 PM
75Highboy460
Old Jan 23, 2006 | 09:27 PM
Torque1st's Avatar
Torque1st
Posting Legend
Remember to add a proper filter in that return line.
Wix Transmission/PS Filter
Wix transmission/PS filter #58964
Ford equivalent filter kit #XC3Z-7B155-AA
Ford filter alone #XC3P-7B155-BA
200 psi working, pressure relieved, magnetic
change yearly or 12000 miles
Old Jan 23, 2006 | 09:30 PM
75Highboy460
This is what NAPA thinks I need. This differs quite a bit from what LMC says I need. Neither look like what is on the truck now! I know that I have the correct information for the searches, but it is pot-luck as to what modifications have been done to this truck in the last 30 years.
I suppose that I should just buy some bulk hose and clamp it.
Noel
Old Jan 24, 2006 | 08:51 PM
thelonerangerxlt
Highboy, the return hose on my 78 Bronco looks like the NAPA picture.
The picture in my LMC catalog is a generic hose that looks nothing like mine either.....?
The stock return hose has a metal line in the middle, to enable it to make the twists and turns so as to fit between the frame rail and the PS unit without kinking.
Old Jan 24, 2006 | 09:33 PM
robtinalimon's Avatar
robtinalimon
Go to a local hydraulics shop or forklift repair facility. You may be able to get one that matches the one you need. I used the NAPA hoses and they were good to go.
