Sponsored by: Real Truck
stalling issues
Old Jan 26, 2012 | 07:59 AM
PhilTuck's Avatar
PhilTuck
Question stalling issues
My 2005 v10 stalls out after it is warmed up. Sometimes at stops, sometimes when backing up, sometimes when shifting. This started after battery went dead while servicing plow. Cleaned connections and charged battery. Problems starting with stalls, now my hub auto locks are not engaging. I not sure if this is related. I pulled vacumm line off when engine not running and is was holding pressure so I don't believe there is leaks. Looking for direction, trying not to go to dealer. There are no codes showing up either.
Old Jan 26, 2012 | 08:25 AM
Byram's Avatar
Byram
You might check/clean the MAF Sensor..
Old Jan 26, 2012 | 05:13 PM
1973Ford2004's Avatar
1973Ford2004
With no codes showing, my experience is a bad COP, get someone with a good reader that will be able to tell you which cylinder is misfiring or search the forum on ways to tell which COP is bad, but I'd start with the COP
Old Feb 16, 2012 | 11:38 AM
PhilTuck's Avatar
PhilTuck
Update
I cleaned my MAF sensor and tried to get to my IAP to clean and free up(very hard to get to where located) i ended up spraying cleaner thru intake. Worked for awhile but still ocassionally tries to stall out. I also have been running high test in it for gas. Wondering if a Lucas treatment would help?
Old Feb 16, 2012 | 06:47 PM
twodazeoff's Avatar
twodazeoff
I just cleaned my maf sensor and the throttle plates. Make sure you have someone turn on the key and step on the throttle to open the plates. I use air intake cleaner. This seems to have fixed the same problem with my 05 v10.
Rodv10mittan
Modular V10 (6.8l)
20
Sep 26, 2016 01:44 PM
bubbachubba
Apr 6, 2015 11:05 PM
tritonking
Modular V8 (4.6L, 5.4L)
16
Nov 23, 2011 03:26 PM
db1068
Dec 9, 2010 12:42 PM
Myfirstnewtruck
1997 - 2003 F150
Nov 11, 2004 05:44 PM
