My 2005 v10 stalls out after it is warmed up. Sometimes at stops, sometimes when backing up, sometimes when shifting. This started after battery went dead while servicing plow. Cleaned connections and charged battery. Problems starting with stalls, now my hub auto locks are not engaging. I not sure if this is related. I pulled vacumm line off when engine not running and is was holding pressure so I don't believe there is leaks. Looking for direction, trying not to go to dealer. There are no codes showing up either.
With no codes showing, my experience is a bad COP, get someone with a good reader that will be able to tell you which cylinder is misfiring or search the forum on ways to tell which COP is bad, but I'd start with the COP
I cleaned my MAF sensor and tried to get to my IAP to clean and free up(very hard to get to where located) i ended up spraying cleaner thru intake. Worked for awhile but still ocassionally tries to stall out. I also have been running high test in it for gas. Wondering if a Lucas treatment would help?
I just cleaned my maf sensor and the throttle plates. Make sure you have someone turn on the key and step on the throttle to open the plates. I use air intake cleaner. This seems to have fixed the same problem with my 05 v10.
