Installing Coolent Filter
Old Jan 26, 2012 | 06:11 AM
JonArmy's Avatar
JonArmy
I got my coolent filter yesterday and need everyone's input.
I'm planning on draining the coolent so I can install the filter without losing coolent then install filter and refill with what was taken out. My question is if that would be a good idea or should I do a complete flush and then put fresh coolent in. I had my coolent flush and refilled about a month ago so it should still be good.
Old Jan 26, 2012 | 06:44 AM
Jakebrake's Avatar
Jakebrake
< Samantha...my Co-Pilot
You will not need to drain all your coolant...just about a gallon or so. If you filter setup tees into the heater line that will drop the level low enough so that you don't lose much. Which coolant filter system did you get?
Old Jan 26, 2012 | 07:12 AM
watatrp's Avatar
watatrp
I just used some clamps on the hose before I made my cut. Lost maybe a few ounces of coolant.
Old Jan 26, 2012 | 07:35 AM
Smokeispower's Avatar
Smokeispower
No need to drain the system, but remember to relieve the pressure by loosening the cap on the degas bottle. Only lost about half a cup doing mine, and didn't bother (didn't think of) clamping the lines.
Old Jan 26, 2012 | 07:38 AM
JonArmy's Avatar
JonArmy
I got my coolent filter from dieselsite, I also got the ball valvesa for easy change
Old Jan 26, 2012 | 07:41 AM
Jakebrake's Avatar
Jakebrake
Do yourself a favor and don't re-use the lousy spring clamps that Ford uses. Replace with a quality worm screw clamp and you will be miles ahead.
Old Jan 26, 2012 | 08:32 AM
Jimbob8's Avatar
Jimbob8
I installed mind as instructed, moved it after first filter change to bumper bracket in right front, cut bracket, drilled 2 holes & 1/2" nuts as spacers. Routed hoses thru existing openings by washer bottle. Easy to change & on spillage in engine compartment.
Ford Truck Enthusiasts Forums - Jimbob8's Album: coolant filter
Old Jan 26, 2012 | 11:23 AM
Misky6.0's Avatar
Misky6.0
I like that. I have my Dieselsite coolant filter in the recommended
location near the pass side battery, and it's a challenge to replace
the filter - I can barely get my hand in there.
AzSuperDuty
Mar 8, 2015 02:43 PM
samsdad02
Oct 20, 2012 10:17 AM
DieselVol
Aug 13, 2012 01:49 PM
drewworm
Aug 31, 2007 04:58 PM
mtgrzlyman
Oct 28, 2006 10:14 PM
