D60 front 4x4 problem
Old Jan 25, 2012 | 06:07 PM
f350rebel7788's Avatar
f350rebel7788
Disabled USMC Veteran
No, it only does it with hubs locked and t-case in 4. It does it in 4hi or 4lo though. 2wd it goes completely away...
Old Jan 25, 2012 | 07:50 PM
fordpride's Avatar
fordpride
If it's only doing it when the hubs are locked I'd say it's in the hub. What happens if you lock one hub at a time? It might tell you what side it is. Just my .02 I know very little about 4WD
Old Jan 25, 2012 | 09:55 PM
ReBilld's Avatar
ReBilld
If it only makes that noise with th hubs locked in, check the pinion bearing. It's amazing how sound can travel through the driveline. I had a simular experience with a '95 F250 I used to have. Could've sworn the t-case was coming apart, turned out to be a worn locking hub.
Old Mar 28, 2012 | 10:59 PM
f350rebel7788
well guys, I just replaced the self centering yoke inside the double cardan joint and problem solved FINALLY!!!! Now i just need to get used to it working properly! lol Kinda irritating that i literally replaced every other joint in the equation, but hey, atleast i know everything is in good condition! thanks everyone fir the advice, and Nate, all i can say is sorry it took me so long to listen, but thank you for constantly sayin it! lol you're awesome! as soon as i can i'll have the reps sent!
Old Mar 29, 2012 | 05:57 AM
DIYMechanic's Avatar
DIYMechanic
Glad to hear you got it fixed! And like you said, at least now you know for sure that everything under there is in good condition.
tsevrens
May 31, 2017 04:52 PM
sunbelt57
Jan 15, 2015 03:13 PM
ksidlosky
Offroad & 4x4
Apr 2, 2013 08:23 PM
LSO1123
Nov 24, 2011 12:56 PM
f350rebel7788
Sep 26, 2011 05:08 PM
