D60 front 4x4 problem
Old Jan 25, 2012 | 02:22 PM
f350rebel7788's Avatar
f350rebel7788
Disabled USMC Veteran
Cool D60 front 4x4 problem
Okay, so this is probably my 5th post about this problem, and every time i think i have it figured out, it's still not the problem. here's what it's doing:
it's loudest at the beginning and end of the video... 4 wheel drive clatter - YouTube that clank you hear... sounds like metal on metal hitting as the wheel turns. sounds like it's coming either from the differential or somewhere to the left of it, right underneath the pedals. the 4x4 still works, it's just making that sound, which tells me somethings not right, and i'd rather figure it out now than find it when it breaks.
here's what i thought it was and what i did:
first, i thought it was a driveshaft u-joint. replaced them all.
then i thought it was the passenger side wheel u-joint. replaced that one.
then i thought maybe an internal problem in the diff like missing gear teeth. pulled the diff cover, spun all the gears, nothing missing and no metal flakes in the fluid.
then i thought drivers side u-joint. replaced it.
checked all the splines on the shafts, all the gears in the hubs, and everything looks fine.
now it's still freakin doing it!!! the only thing i can think of is maybe it's a problem with the manual hubs??? when i replaced the wheel u-joints i locked/unlocked the hubs while they were off the truck and everything seemed fine. this really has got me stumped, cause i'm pretty sure that covers everything it could be! anyone got any ideas? at this point i've pretty much settled on taking it to a shop and just saying, "tell me what's broke"...
Old Jan 25, 2012 | 02:33 PM
riverrat41's Avatar
riverrat41
I know it is a pain but have you put all 4 wheels on jack stands and had someone put it it gear and you listen while it is up on stands?That is a tough one beings you have changed all that you have.I just wonder if that drivers front hub is really engaged?Wonder if you could stop that side by hand or would it keep pulling if it was all on stands?
Thank you for your service!!!
Old Jan 25, 2012 | 02:38 PM
DIYMechanic's Avatar
DIYMechanic
Daniel, I know we talked about this before, but does your truck have the double cardon joint in the front drive shaft? I am wondering if it isn't staying centered or something and is flopping around when there is pressure on it.
Old Jan 25, 2012 | 03:00 PM
f350rebel7788
that's one thing i might just have to try... just gotta get a couple more stands and a friend, then work up the cajones to crawl under the truck... lol
And thank you for your appreciation!
I'm still not 100% sure i know what the double cardon joint is, but here's some pics of what i have.
here's the front where it connects to the axle
here's the back where it connects to the t-case
and this may be the joint you're talking about?
Old Jan 25, 2012 | 03:13 PM
riverrat41's Avatar
riverrat41
I would in no means lay under the truck .I was talking about getting someone in the drivers seat and you kneel down on the outside of the tire to see if you can pinpoint the noise and see if that one is pulling or not.
Old Jan 25, 2012 | 03:16 PM
f350rebel7788
haha yeah, that's just my "hey yall watch this" humor! lol
Old Jan 25, 2012 | 03:19 PM
riverrat41's Avatar
riverrat41
I gotcha...Send the neighbors kid under there.
Old Jan 25, 2012 | 03:21 PM
f350rebel7788
ya know, there are a couple spoiled little brats running around here... haha
Old Jan 25, 2012 | 03:23 PM
f1501987's Avatar
f1501987
Looks like you have the double cardon joint to
Old Jan 25, 2012 | 03:32 PM
tjc transport's Avatar
tjc transport
i ain't rite
the double cardon joint is the last one pictured
Old Jan 25, 2012 | 03:44 PM
f350rebel7788
so that joint would cause that clanking sound??? it doesn't sound like it's coming from that far back to me...
Old Jan 25, 2012 | 03:47 PM
DIYMechanic
3X the double cardon joint is that last picture. It has two u-joints joined together and takes a special "self centering yoke" that keeps everything straight. Basically it is designed to divide the angle across 2 u joints instead of kinking one joint at a severe angle. Here is a link to my rebuild thread.
https://www.ford-trucks.com/forums/1...t-bearing.html
If the bearings in the self centering yoke are bad or the spring in the joint is broken, it may be binding or clicking. An easy test would be to pull the front drive shaft out of the truck, lock the hubs in and drive it a little to see if you still have the noise. I am willing to bet you won't and the joint is the culprit. It's an easy test too since it only takes one wrench and a few minutes to drop the front drive shaft.
Be sure you let us know what you find.
Old Jan 25, 2012 | 05:10 PM
dclack's Avatar
dclack
...lock the hubs in and drive it a little...
You can put the t-case in 4hi also to make sure it's not something internal to the t-case.
Old Jan 25, 2012 | 05:30 PM
BlueMule's Avatar
BlueMule
Does it do it if you engage the transfer case with the hubs unlocked? What about with the hubs locked and the transfer case in 2wd. Maybe swap the hubs to the opposite sides and see if the noise follows the hub or stays on the drivers side. Maybe even the bearings. Not only the hub bearings but there is also a set inside the spindle that the stub shaft rides on that are often neglected.
Old Jan 25, 2012 | 05:42 PM
DIYMechanic
FWIW, when my cardon joint went bad, I couldn't hear any noise with the T case in 4HI and the hubs unlocked b/c there was no pressure on the joint. With the hubs locked in and the T case in 2HI I could just faintly hear the noise, but it was very faint.
