1996 f250 wont SHUT OFF quick its running
Old 03-28-2012, 07:11 PM
duggyb's Avatar
duggyb
duggyb is offline
hahaa sooo weird.
just changed my GPR put in a echlin(NAPA) GPR-109 fired it up and now the truck wont shut off, key turns off and gauges power down but truck stays running.
what did i do wrong? mixed up the wires maybe?
how can i shut it off safely? and fix this issue?
QUICK! Thanks in advance
DUstin
Old 03-28-2012, 07:19 PM
BlueMule's Avatar
BlueMule
BlueMule is offline
The #2 relay in the distribution box under the hood is for the IDM, unplug it.
Old 03-28-2012, 07:24 PM
BlueMule's Avatar
BlueMule
BlueMule is offline
As long as you put the big wires on the big terminals and the small on small there's no way to wire the GPR wrong. I wonder if NAPA had the wrong relay in the GPR109 box? If you remove the new relay does the truck start and stop like it's supposed to?
Old 03-28-2012, 07:26 PM
duggyb's Avatar
duggyb
duggyb is offline
THANK YOU!
i didnt want to starve it of fuel or anything anf cavitate my pump.
so now the question is what went wrong?
i get no wait to start light, and my battery and abs lights are on.
i unplugged negatives on both batterys before i changed my gpr.
did i mix up some wires on my gpr?
Thanks.
Dustin
Old 03-28-2012, 07:27 PM
duggyb's Avatar
duggyb
duggyb is offline
i will swap the old one in right now and check
Old 03-28-2012, 07:35 PM
duggyb's Avatar
duggyb
duggyb is offline
yupp truck functions fine with old gpr
the gprs look the same like size and mounts and all
this is odd
Old 03-28-2012, 07:41 PM
BlueMule's Avatar
BlueMule
BlueMule is offline
They gave you the wrong one. Most relays (like the starter relay on the right fender) are grounded through the case and mounting screw. The GPR relay is isolated from the ground and the ground is supplied by the PCM through one of the small wires.
Old 03-28-2012, 08:41 PM
fordpride's Avatar
fordpride
fordpride is offline
I had a gpr short and cause the same problem
Old 03-28-2012, 08:55 PM
duggyb's Avatar
duggyb
duggyb is offline
short internally? or externally.
mayabe one of my wires is rubbing on another in the loom?
Old 03-28-2012, 10:24 PM
duggyb's Avatar
duggyb
duggyb is offline
sure enough that was my issue!!
one of the terminal ends had a bare spot on the bottom which was just so touching another wire, looks like i may have clamped it down on top of the other one, or the previous owner did, probably me though. So the new GPR works fine, but we will see how good in the morning when its cold...im excited as i hope it fixes my long white smoke starts
thanks everyone for the help!!
last question, while in there i noticed a hose at the very bottom of the fuel bowl was not attached to its nipple which is a attached to a long black plastic thing running up the side of the bowl externally, (Passenger side)
i never hooked it back up(which i think i should?) i just want to know what it is ahead of time.
Thanks.
Dustin
Old 03-28-2012, 11:04 PM
stainlessstroker95's Avatar
stainlessstroker95
stainlessstroker95 is offline
Does it run up to a yellow lever? Sounds like the drain valve for the fuel bowl,
Old 03-28-2012, 11:08 PM
duggyb's Avatar
duggyb
duggyb is offline
yes it appears thats where it runs, where does the hose go though?
also whats the proper procedure for draining this, im assuming i should do it sometime as its prolly never been done.
Old 03-29-2012, 06:29 AM
redman84's Avatar
redman84
redman84 is offline
Turn the yellow lever 90* from its current position. Without the drain hose and pipe hooked up a mess will ensue fyi.
subjlog
06-14-2017 08:36 AM
Larry Wall
02-26-2015 09:38 AM
SeannyBoy84
Modular V8 (4.6L, 5.4L)
07-01-2009 08:31 PM
2kcrewcab
02-25-2007 07:48 AM
tbonelynch
1983 - 2012 Ranger & B-Series
07-14-2006 07:21 PM
Quick Reply: 1996 f250 wont SHUT OFF quick its running
