Interior cab rust
Old Jan 24, 2012 | 04:53 PM
77393's Avatar
77393
Interior cab rust
I put this in the paint and body section with no response, can somebody help me out?
The previous owner decided to cut holes and put 6x9 speakers behind the seat. He also stuffed the inside of the cab inbetween the rear glass and the door jamb with pillow stuffing. Over time this soaked up moisture and now I have rust in places I can't get to. I have heard horror stories about dipping cars in acid. The rest of the cab is solid. How do I stop this internal rust?
<!-- / message -->
<!-- controls -->
Old Jan 24, 2012 | 04:55 PM
JB78f150's Avatar
JB78f150
Ya this is why there is nothing in there in the first place. Sorry I can't help you out.
Old Jan 24, 2012 | 05:06 PM
bdevr's Avatar
bdevr
If you can't get to it, can you at least tell how bad it is? If it's only surface rust maybe clean it the best you can and try putting something like por15 (or any similar system) in a cheapo garden sprayer and go to town?
Old Jan 24, 2012 | 05:24 PM
ctubutis's Avatar
ctubutis
This is what comes to my mind, too; rust will grow only when it gets wet, so keep it from getting wet.
Old Jan 24, 2012 | 05:31 PM
turbohunter's Avatar
turbohunter
Oh brother.
First off, good luck be with you. You are going to have to access the level of damage. Use a flashlight, mirror, scraper, screwdriver, whatever you can to poke and prod to see if the rust is surface or gone through. Don't be gentle, you need to know. You can't tape over a panel that has no integrity, you have to fix it.
Once you have that figured out it will be a bit more clear as to what you can do. If it has rusted through you need to install replacement panels.
If it is just surface rust you can use one of the rust stopping compounds.
On my truck I had both problems. My drivers side floor was rusted through. Had to weld in a new section. In the areas with surface rust I used Permatex Rust Stopping crud. There are a few different ones out there.
The point is, you have to attack it or it will attack you.
Have fun.
Old Jan 24, 2012 | 07:15 PM
Blue and White's Avatar
Blue and White
Agree you need to determine if the rust is perforated or structural. If not, a wax based rustproof coating will help a lot in stopping further rusting. The stuff below works well. You can apply with a rust proof gun (flexible plastic wand with all direction nozzle at the end) or brush. Also available in aersol with the flexible applicator.
One caution... it goes on messy and smelly. Within a day or so it sets up and after a week or so the smell goes away... at least mostly.
Solutions /
<LI class=category236>Prevention / <LI class=product>Heavy Duty Anti Rust Qt 32oz
<!-- code added on Oct 23, 2010 for web1by1 script --><!-- end of code added on Oct 23, 2010 for web1by1 script -->
<FORM id=product_addtocart_form method=post action=http://www.eastwood.com/checkout/cart/add/uenc/aHR0cDovL3d3dy5lYXN0d29vZC5jb20vZXctaGVhdnktZHV0eS 1hbnRpLXJ1c3QtMzJvei5odG1s/product/341/><FIELDSET class=no-display><INPUT value=341 type=hidden name=product> <INPUT id=related-products-field type=hidden name=related_product> </FIELDSET>
Enlarge product image
Item #16017 ZP
<!-- code added on 25 Oct 2010 to view the In Stock message -->In Stock - Ready to Ship Today
<!-- end of code added on 25 Oct 2010 to view the In Stock message -->Only $19.99
  • Buy 3 or more for $19.49 each and save 3%
Heavy-Duty Anti-Rust protects internal surfaces against rust
Works with your undercoat spray gun to apply an amber-colored, waxy film that sticks to bare metal or painted surfaces, and won't crack, flake or peel. Use inside frames, doors, rocker panels or on any exposed
</FORM>
Old Jan 24, 2012 | 07:34 PM
77393's Avatar
77393
I will take a further look with flashlight, mirror, and long prybar. The speaker holes just have surface rust right behind where the speaker was, not sure how far it traveled. Thanks alot.
Old Jan 24, 2012 | 08:53 PM
77393's Avatar
77393
Well looks like she survived a stupid mistake the PO made. Its just surface rust and did not spread anywhere else. I;m going to spray some of the Eastwood Anti rust, all around in there so I won't have to worry about that anymore. Theres a small place around the rear glass seal in the same shape. Thanks alot guys, for your help.
Old Jan 25, 2012 | 03:42 AM
turbohunter
Whoohoo.
Your on easy street.
3/4ton4X4
May 29, 2015 10:55 AM
powerstroker100
May 1, 2015 06:01 PM
JustBlaze
Apr 23, 2011 12:22 PM
Blackwaterforge
Aug 4, 2008 09:00 PM
wildcat99
Paint & Bodywork
Apr 2, 2007 08:31 AM
