1977 Front Driveshaft
Old Jan 24, 2012 | 07:15 PM
lastclodstanding's Avatar
lastclodstanding
Hey guys....I've searched until I am blue in the face. I got a 1977 F150 351m/C6/NP208(so I was told, tag is gone), DANA 44 front and Ford 9in rear. It has been awhile since I messed with these style trucks. I remember the front drive-shaft having a CV joint (double cardamon) from past trucks. Well the one I picked up had the front driveshaft out. I pulled it from the box of parts lastnight and started the clean and rebuild with new ujoints and fresh paint. It doesn't have the CV joint though. Am I crazy or is it missing? Do some applications not have the joint? I also have suspensions that the shaft isnt factory. On the male part of the slip joint I can tell its been cut down (shortened).
Two more things....on the female side of the shaft there is threads....did this use to have a socket that would hold a seal? Also having trouble remembering which end of the driveshaft goes to axle and to xfer case. Ie...which end is the slip suppose to be towards?
Thanks ahead of time.
Camaron
Old Jan 25, 2012 | 06:48 AM
lastclodstanding
Just a forum bump...if anyone has a picture of their factory setup I would greatly appreciate it.
Old Jan 25, 2012 | 07:32 AM
OldStyle's Avatar
OldStyle
Rusty Roller
77 Drive shaft:
Johnkimble
Jun 12, 2019 11:00 AM
swampthang
Mar 23, 2018 10:30 AM
phil75j
Mar 1, 2014 08:56 PM
clhart426
May 17, 2011 03:19 PM
93FordCTD
Offroad & 4x4
Jan 11, 2010 11:46 PM
