As far as I know, you get either a serpentine or v belt version from a van. You get lucky and find one with the same size bolt hols as your AC bracket, or you have to drill them yourself. The pressure hoses are bent differently and most people opt for new so they can easily rebent, other than that, there's not much more to it.
Thanks Brett i will look into probably getting the one from JBG and maybe find a pump wither at the local junk yard or see if my work carries them, being GM and all they should.
ok....who can find me Saginaw brackets for a 300 I6 ??
Sorry the 6cyl brackets that JBG "will only fit a 170 or 200. I don't have one available for the 300."
That is what JBG tech said.
I guess I will be looking around at junkyards.
