power steering pump
Old Feb 12, 2009 | 04:17 PM
windsor94's Avatar
windsor94
power steering pump
how hard is it to replace a power steering pump in a 94 or any other year with a 5.8l 351? Estimated time?
Old Feb 12, 2009 | 04:39 PM
BCHauler's Avatar
BCHauler
Do a search on saginaw powersteering pump swaps. I had a whining and puking Ford pump in my 94 truck that I swapped out with a used Saginaw style pump from a 94 Clubwagon and it wasn't that hard. This pump is stronger and quieter and its fairly straight forward. I highly recommend this swap if your pump needs replacing.
Old Feb 12, 2009 | 05:54 PM
1994 F250: 351, C6's Avatar
1994 F250: 351, C6
I second BCHauler on the Saginaw swap. When my PS pump bites the dust I am replacing it with a Saginaw. The Saginaw swap does not look to tough either. A straight replacement of the stock pump is super easy. You will need a power steering pump pulley puller/installer, a lot of autoparts stores rent them. Make sure you get one that installs the pulley in addition to pulling it. DO NOT hammer it on. Below is a link to the tool I own, it cost about $60.
Detail Page for 38850 Pulley Puller / Installer - Lisle Corporation
Old Feb 12, 2009 | 11:53 PM
windsor94's Avatar
windsor94
Uh, ya I think my pump needs replaced now, I have no powersteering at all. Last she worked, she wined and then just blew or something cause its a chore steering now.
Old Feb 13, 2009 | 12:21 AM
deeznuts822's Avatar
deeznuts822
Check the seal at the pitman arm, when these leak it will empty the ps pump pretty fast. The seal kit is like 20 bucks takes about an hour to change because u have to pull the pitman arm. Once u do theres a snapring u remove then put a lil fluid in and turn the steering wheel to full right and it pops rite out
Old Feb 13, 2009 | 12:56 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
D7AZ3E501B .. P/S Gearbox - Sector Shaft Seal Kit
MSRP: $21.98 // FTEpartsguy.com price: $15.83
F3AZ3E502A .. P/S Gearbox - Input Shaft Seal Kit
MSRP: $21.83 // FTEpartsguy.com price: $15.72
Both kits fit: 1969 F100/350's after serial #D96,000, all 1970 and later F100/350's thru at least 1996.
Fits many other cars/trucks. Type one of the part numbers into FTEpartsguys site to see some of the dozens of applications.
Old Feb 14, 2009 | 01:22 AM
windsor94's Avatar
windsor94
my pitman arm seal went along time ago, I just drove it around and after it sat I'd always made sure it had steering fluid. So does it sound like a new pump or more/less to it?
Spktyr
Jul 16, 2014 09:21 AM
jmikeyj4
Feb 16, 2014 12:36 PM
blacklab1
Aug 16, 2013 11:33 AM
Andfall
Mar 21, 2011 02:33 PM
wjawill
1978 - 1996 Big Bronco
Nov 8, 2004 02:44 PM
