429 won't start
Old Jan 23, 2012 | 07:09 PM
Austin J.'s Avatar
Austin J.
429 won't start
It is a 1989 F-700 with the 429. It cranks fine but won't start. It started out by just dyeing randomly. It didn't sputter or anything, it was like you turned the key off. I know that there is power going to the coil, the coil is good, and so is the cable from the coil to distributor. The distributor is where I get stuck. It has compression, but it won't even stutter with starter fluid.
Old Jan 24, 2012 | 09:01 AM
yewdall's Avatar
yewdall
Sounds a lot like a bad condenser... seen that on older fords a few times. Except that it most certainly is electronic ignition by that year.
But, I've had the same symptoms on subaru's of that era with a bad pickup module in the distributor, so you might want to check that (not sure how to check other than just replacing it though) Sometimes runs fine... and sometimes just no spark at all.
Have you checked for spark yet?
Z
Old Jan 24, 2012 | 10:12 PM
Austin J.'s Avatar
Austin J.
Thank you, whenever it dries up and warms up a little I will get a little bit more into it.
Feb 22, 2013 10:37 PM
KUE798578
36
Nov 6, 2012 11:18 PM
sleepy_fella
Apr 3, 2011 09:23 PM
masterclean5
Oct 13, 2010 12:00 AM
manlikesford
Apr 23, 2005 07:39 PM
