voltage draw
Old Jan 23, 2012 | 01:19 PM
Jayme Duty's Avatar
Jayme Duty
voltage draw
I Still have something that is draining my batteries over night. I am taking the alternator in right now to test the voltage regulator. Should also mention that while the glow plugs cycle at first start the tach moves up to about 350 rpm. what causes this? If anybody knows of anything that will draw power over night and how to test them please let me know.
Old Jan 23, 2012 | 02:51 PM
Lazy K's Avatar
Lazy K
If you disconnected the alternator and still get the draw then try this. Lift off the main neg battery terminal and connect a small test light between it and the neg battery post. If there is a current draw somewhere the light should glow. Now start pulling fuses. If, when you pull one, the light goes out you need to then check that circuit.
Old Jan 23, 2012 | 03:18 PM
Jayme Duty's Avatar
Jayme Duty
that is great thank you Lazy K. I will play with that tonight.
Old Jan 23, 2012 | 07:46 PM
Jayme Duty's Avatar
Jayme Duty
I did the test light trick and found the fuse, does anybody have the fuse box diagram for a 94. It is in the box under the hood. It is the first little fuse closest to the fender. 20A.
Old Jan 23, 2012 | 07:52 PM
turtlemann14's Avatar
turtlemann14
is there not a diagram on the back of the lid?
Old Jan 23, 2012 | 08:01 PM
Jayme Duty's Avatar
Jayme Duty
that is a very good point. It was so dark when i was out there i didn't notice. I will go look
Old Jan 23, 2012 | 08:05 PM
bashby's Avatar
bashby
They are just numbered... the owners manual tells what's what.
Old Jan 23, 2012 | 08:08 PM
Jayme Duty's Avatar
Jayme Duty
does not say anything except STD 1 (hope its not Gonorrhea)
Old Jan 23, 2012 | 08:15 PM
bashby's Avatar
bashby
If you dont have an owners manual I suppose I could put pants on and go out and get mine, then tell you what's on that circuit.
Old Jan 23, 2012 | 08:18 PM
Jayme Duty's Avatar
Jayme Duty
When i bought my truck i did not have one
Old Jan 23, 2012 | 08:28 PM
bashby's Avatar
bashby
my owners manual says fuse#1, 20a is for headlamp flash to pass and daytime running lamps (Canada only). That's from my 92 F250. Autozone.com has wiring diagrams under repair guides that might tell you more. You have to register on their site (free) to access repair guides.
Old Jan 23, 2012 | 08:47 PM
Jayme Duty's Avatar
Jayme Duty
I just found a link to power dist box that shows fuse #1 20A = radio I guess tomorrow ill turn the key on without the fuse and see if the radio stays off. If so that should be easy enough to fix i know exactly which wire is the hot wire to the radio.
Old Jan 23, 2012 | 08:54 PM
bashby's Avatar
bashby
The wiring diagrams sometimes shows things on the circuit that the owners manual doesnt mention.
Old Jan 23, 2012 | 09:00 PM
Jayme Duty's Avatar
Jayme Duty
then i just found another diagram that says exactly what yours says, which i don't really understand
Old Jan 23, 2012 | 09:06 PM
bashby's Avatar
bashby
My manual shows fuse #11 under the dash for the radio... mine is a 92 though.
