Injector pump solenoids
Old Jan 22, 2012 | 06:05 PM
Freddy.ca's Avatar
Freddy.ca
can anyone tell me if the terminals are always on with key(hot) i believe one is a fuel shutoff solenoid and the other is a cold start. i had an issue with no power from the key, so i bypassed and put a manual lit switch in the cab to activate. any help or photo's diagrams would help thanks.
1987 Ford F-250 7.3 non turbo
Old Jan 22, 2012 | 07:20 PM
Phy's Avatar
Phy
The fuel shut-off solenoid is supposed to be hot anytime the key is on. The other one is the cold advance. That one, and the high idle are hot until the the engine get up to a certain temp.
What's wrong with the power from the ignition switch?
Old Jan 22, 2012 | 10:06 PM
Freddy.ca's Avatar
Freddy.ca
broken wire in the harness somewhere causing my fuel shutoff to be intermittent. i'll get to that when the weather gets better.
ok so the cold advance and high idle i can shut off. thanks
banicman
Dec 4, 2012 10:42 AM
thedieselkid
Jul 21, 2011 12:52 PM
ncfirefighter46
18
Feb 8, 2008 12:55 PM
ditch witch
Feb 4, 2006 07:44 AM
powvey
Mar 3, 2005 06:38 AM
