wiring injector pump
Old Jul 19, 2011 | 05:32 PM
thedieselkid's Avatar
thedieselkid
hi truck wiring is all messed up.
Anyone know how i could wire up the IP pump??
I know the fuel solenoid has to be hooked up to ignition.
What about the other 2 terminals. One is a idle control solenoid that has a plunger that comes out. the other i have no idea but when i put 12+volts on it it make engine rpm change.
TIA
Old Jul 19, 2011 | 05:40 PM
swooshcmk's Avatar
swooshcmk
The other 2 terminals are an internal advance, and the one on the side is the idle kick solenoid. Both of those 2 terminals should be wired to a temperature switch on the front right of the engine near the thermostat housing (2 spade terminals) They kick on when the engine is cold to provide advanced timing and high idle speed and then shut off once the engine reaches ~120* if I remember right.
Old Jul 19, 2011 | 10:32 PM
starmilt's Avatar
starmilt
These are not required to run, although they can be nice in the winter.
Old Jul 21, 2011 | 12:52 PM
thedieselkid
thanks. Looks like 12volts runs through that switch with no relay or anything???
chaoticghost
23
Mar 15, 2017 05:23 PM
kjs5055
Aug 4, 2016 02:42 PM
Cdeming
Aug 1, 2016 06:04 PM
leefarmfixer
30
Dec 28, 2015 08:13 PM
gtotiger65
Jun 21, 2015 01:35 AM
