Transmission cooler options
Old Jan 22, 2012 | 04:52 PM
reed1951's Avatar
reed1951
Hey guys, I have seen other guys on fte use those long aluminum "finned" trans coolers in the "c" of their frame rails basically right next to the transmission. I think it looks great and routing the cooler lines would be a lot easier lol I am on my phone so I can't post a link of the type of cooler I'm talking about now but will later. I was thinking about using a 30" one in between the frame rails. BUT I am kind of worried about that location inside the frame like that. Would it keep my stock AOD cool enough?
Edit} here we go:
http://www.ebay.com/itm/ALUMINUM-30-...#ht_1404wt_956
Old Jan 22, 2012 | 05:04 PM
53pickemuptruck's Avatar
53pickemuptruck
I got one similar ,but was afraid to try it,i opted out for a double row radiator type with a cooling fan mounted to it. Iwas afraid the finned one wouldn't be enough altough they say it would cool ok. Not running yet so wont know how good this one works.
Old Jan 22, 2012 | 05:24 PM
sdetweil's Avatar
sdetweil
I switched from the radiator cooler to the finned style mounted on the chassis when I had my engine overheat problems year before last.
Unless you intend to spend a lot of time in bumper to bumper traffic you should be fine. Mine is the 18 in version. I didn't measure any real change in tranny temps.
I have moved it over to my 56 as the only cooler.
Sam
Old Jan 22, 2012 | 08:10 PM
jamesadams's Avatar
jamesadams
I have been using a power steering cooler from a 78 f 150 on my 64 c10 turbo 350 with a stage 3 shift kit for about 15 years now. Drove the heck out of it no problems yet.
Old Jan 22, 2012 | 10:20 PM
1oldtimer's Avatar
1oldtimer
my C6 likes to run hot, I used 2 stacked plate trans coolers side by side. With the grille on it kinda hides it.
Old Jan 23, 2012 | 07:31 AM
CharlieLed's Avatar
CharlieLed
I think that this is the setup that you were referring to...
Old Jan 23, 2012 | 12:46 PM
dawolverine's Avatar
dawolverine
I'm using one - have had no trouble at all with it.
Old Jan 23, 2012 | 01:02 PM
sdetweil's Avatar
sdetweil
that is what I have on the red truck, altho the cooler is hung on the bottom of the frame rail.. behind the battery box.
Sam
Old Jan 23, 2012 | 03:39 PM
DR Smith's Avatar
DR Smith
I have a fin style cooler thats like a little radator mounted under the pass running board.It lies flat with about 2 inches of space between it and running board. 17,000 miles and no problem.I tow my boat and utility trailer [16 ft ] with it.
Old Jan 23, 2012 | 05:24 PM
reed1951's Avatar
reed1951
Thanks guys for all your help!
Byrd.Dog
May 14, 2018 08:09 AM
Pladsmand
15
Jan 31, 2018 03:07 AM
BigBlueX
Aug 26, 2015 11:41 AM
SCRAPHEAP51
Jan 30, 2011 01:29 PM
zsir
Aug 28, 2005 01:40 AM
