transmission cooling
Old May 12, 2018 | 10:27 AM
Byrd.Dog's Avatar
Byrd.Dog
Didn't see a forum specifically for transmissions, so I figured I'd just post here where I hang out the most. I've got a C6 that's currently plumbed into an integrated cooler in my radiator. I'm thinking about going with a dedicated tranny cooler & wondered if anyone had any experience with the "Heat Sink" type coolers? I like the look and the form factor, & it looks like they're full flow. Opinions???
Old May 12, 2018 | 08:11 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
My opinion is to NOT delete the radiator cooler. It's a highly efficient cooler and you'll lose a lot of cooling if you remove it.
Old May 13, 2018 | 07:07 AM
Byrd.Dog's Avatar
Byrd.Dog
Even the aftermarket ones like champion?
Old May 13, 2018 | 10:33 AM
Mark Kovalsky
You can add an aftermarket cooler, but run the ATF through the radiator cooler first.
I don't know what a champion cooler is. Do you have a link to it?
Old May 14, 2018 | 05:19 AM
Byrd.Dog's Avatar
Byrd.Dog
This is it: CC433
I also have the shroud & electric fans
Old May 14, 2018 | 08:09 AM
Mark Kovalsky
It has a built in transmission cooler. I'd use it.
The reason that the transmission coolers inside a radiator are so efficient is that there is engine coolant surrounding the hot ATF. Water is a FAR better means of extracting heat than air is, so even if the transmission cooler is just a loop of tubing inside the cold end tank it will still remove a lot of heat from the ATF. Then send the ATF to an air to oil cooler out front to cool the ATF even more.
351Cleveland C4
Feb 26, 2014 12:25 AM
LARIAT 85
Apr 8, 2008 09:00 AM
ggirten
Sep 27, 2007 03:45 PM
zsir
Aug 28, 2005 01:40 AM
53fatfndr
Jun 22, 2005 08:41 PM
