15 inch rims?
Old Apr 20, 2003 | 08:32 PM
erikl85's Avatar
erikl85
15 inch rims?
I remember hearing a while back that I couldn't fit 15 inch rims on my f-250. I was wondering why that is? Is it possible to make them fit?
Old Apr 20, 2003 | 08:40 PM
xericx's Avatar
xericx
15 inch rims?
Ford never made 15" rims for 3/4 and 1 ton trucks, and I've never scene aftermarket 15" rims in 8 bolt pattern. Though some aftermarket place will custom make rims for you application, but thats probalby expensive. You could have your rims redrilled for bolt pattern but I'd question the strength afterwards. Hope this helps.
Old Apr 20, 2003 | 09:01 PM
erikl85's Avatar
erikl85
15 inch rims?
I think I have seen many 15 inch rims with a 8 by 6.5 inch lug pattern.
EDIT: Yeah I just checked and there are alot on tyres international.
Old Apr 20, 2003 | 09:07 PM
xericx's Avatar
xericx
15 inch rims?
On What? I know fords ran 16.5's, Dodge and Chevy ran 16's I think.
I'm Checking tyres int right now and cant find any, did you see a 15x8 6-5.5 and mistake it for a 8 on 6.5?
Old Apr 20, 2003 | 09:14 PM
erikl85's Avatar
erikl85
15 inch rims?
I haven't looked for them on actual trucks, but just when I go to the tyre international site there are tons of rims that are 15 inches and have the 8x6.5inch pattern.
http://www.tyres1.com/browse/browseW.html
Anyway, I know that there are 15 inch rims with 8 lug bolt patterns, are there any reasons that they would not fit over the drums or rotors? Or any other clearance issues?
Old Apr 20, 2003 | 09:19 PM
xericx's Avatar
xericx
15 inch rims?
Yeah just found some made by us wheel. First time I've seen a 15" with an 8 bolt pattern. Sorry my bad. But as for clearance issuses, yeah they might hit your rotors and drums not sure though.
Old Apr 20, 2003 | 10:21 PM
Torque1st's Avatar
Torque1st
Posting Legend
15 inch rims?
It can be done with special offsets, spacers, grinding on calipers, etc. There are guys here running them.
Use the search function with some words like:
clearance, grind, calipers, rims, wheels, offset...
Old Apr 21, 2003 | 09:35 AM
460429_freak's Avatar
460429_freak
15 inch rims?
check my gallery under my 79 15 eight lug with 35 12.50 15 tires
Old Apr 25, 2003 | 08:16 AM
4trax's Avatar
4trax
15 inch rims?
They do make 8 lug 15 in. rims. They fit on the back fine it's the front that has problems with the big honken calipers. I've heard of guys grinding down metal on cal. but don't reccommend alot of removal.
Old Apr 26, 2003 | 11:17 PM
Trail_Rider's Avatar
Trail_Rider
15 inch rims?
I put "73 3/4 ton axles under my '72 F100. I was going after the disk brakes, as well as the bigger brakes and bearings. I had a beautiful set of 15" tires I wanted to use, so I ordered a set of 15" 8 bolt wheels specifically for a '73 F250 (that turned out to be my only saving grace), when they came in the rears fit fine, but the fronts wouldn't go on due to interference with the calipers. The tire shop tried to say that the front disk weren't stock, and I reminded them I'd ordered the wheels to fit a '73 F250 - that's the only way I was able to return them (because they were a special order). I ended up buying a complete set of 16"tires and wheels.
Old Apr 27, 2003 | 12:10 AM
RRMike's Avatar
RRMike
15 inch rims?
The problem is with the caliper retainer bolt. If you grind the bolt head a little they will fit fine. I have a buddy with a 78 f250 that had 15" wheels and that's all he did.
oldirtytruck
Offroad & 4x4
13
Sep 21, 2010 10:04 PM
low225
1997 - 2003 F150
Feb 8, 2008 03:17 AM
mengbar
1978 - 1996 Big Bronco
Aug 29, 2005 09:12 AM
noremac19
1983 - 2012 Ranger & B-Series
Aug 13, 2002 08:25 AM
AirKevin23
Sep 14, 2001 10:17 AM
