Transmission Filter trouble......
Old Jan 21, 2012 | 10:25 PM
heathc84's Avatar
heathc84
Hey guys new to the forum here, i had a little problem so figured i would check with you guys, I was changing out my transmission fluid and filters on my 03 f250 6.0 today and did the filter change where the transmission pan is (no problem) but then when i went to change out the external filter (toilet paper one) i could not remove the case around the filter. I even used a torque wrench and it ended up breaking part of the bottom of the external casing is there a special way to remove this? Thanks
Old Jan 21, 2012 | 10:49 PM
powerstroker100's Avatar
powerstroker100
I've heard some people put an impact on it, I havent changed mine yet
Old Jan 21, 2012 | 10:51 PM
bismic's Avatar
bismic
I use an impact wrench - works great.
Old Jan 22, 2012 | 08:46 AM
raptor131's Avatar
raptor131
Did u find it necessary to change the pan filter? I did mine and think that was a waste of time.
Old Jan 22, 2012 | 08:51 AM
69cj's Avatar
69cj
When you re-install the filter, turn till it bottoms out and then only 4 or 5 psi torque. The O ring does the sealing not the threads. Also lube the O ring. I use vaseline but engine oil will also work.
Old Jan 22, 2012 | 08:58 AM
Maxium4x4's Avatar
Maxium4x4
Welcome to FTE heathc84 I see the guys have you covered about using an impact and socket.
Old Jan 22, 2012 | 12:59 PM
heathc84's Avatar
heathc84
No when I opened up the pan the filter was still good looking so it didnt seem like it needed to be replaced but since it was already open I did it any way
Old Jan 22, 2012 | 05:37 PM
King-bRanch's Avatar
King-bRanch
Impact Gun to remove..... when u reinstall do not overtighten & remember to lube the o-ring.........Welcome to the Forum
Old Jan 22, 2012 | 07:28 PM
heathc84's Avatar
heathc84
Cool thanks guys I got it figured out I used a sledge hammer to lossen then I got it to twist off. So thanks for your help guys
Old Jan 22, 2012 | 07:41 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
I'm not looking forward to doing mine next time. I changed all my fluids before really getting to know these little things.
I did ask Santa for an impact gun, and He was more than happy to bring one. So, I'm ready!
1happycamper
Apr 12, 2018 08:44 AM
SuperDutyScaler
Sep 2, 2016 05:58 PM
silverbullet6oh
May 1, 2016 01:59 PM
MY1STCREW
2004 - 2008 F150
46
Feb 20, 2009 12:50 AM
66 Ranger
Jan 15, 2003 01:15 PM
