underhood insulation
Old Jan 21, 2012 | 09:32 PM
johaner78's Avatar
johaner78
Does anyone know where I can get a new piece of the insulation material that is attached on the under side of the hood (engine compartment)? I see LMC sells a huge piece that needs to be cut to fit. anyone found anything that is ready to install? what supplier has it?
Old Jan 21, 2012 | 11:53 PM
F350 Strait's Avatar
F350 Strait
LMC or Bronco Graveyard or
Old Jan 22, 2012 | 12:23 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Only 1975/79 F100/350's w/460's came with a factory installed hood insulator. 23 plastic push pins were required to install it to the hood.
D5TZ-16738-A .. Hood Insulator / Obsolete
23) 386553-S .. Push Pin-1 1/8" round head-claw type-3/4" long / Obsolete
No Ford Dealer or obsolete parts vendor has the insulator.
100's of push pins are available NOS because they were used on other vehicles, but won't do you any good without the insulator.
Most peeps buy the material, then cut it to fit, use spray adhesive to attach it to the hood.
mjr46
Jun 15, 2016 07:40 PM
dsrtjeeper
20
Oct 23, 2012 07:46 PM
salf100
Apr 3, 2010 04:39 AM
bsteele52
Jan 30, 2009 12:00 PM
terriemma1
Sep 9, 2006 03:38 PM
