Hood hinge
Old Oct 10, 2009 | 07:28 PM
salf100's Avatar
salf100
Hood hinge
I bought a drivers side hinge from LMC for the hood of my 64 CC and it fit ok. I just cant get it adjusted right. The hood sits a little high when closed next to the cowl. Anyone have any tips and hows everyone feel about LMC'c products? I need the right side also, but not sure if I should but it from another company.
Old Oct 10, 2009 | 08:13 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1961/66 F100/1100 Hood Hinges
The following are Genuine Ford Parts, not made in China crap!
C2TZ16796C .. Right Hood Hinge / Obsolete
KINSEL L/M in Beaumont TX has TWO = 800-816-2894.
ANTIQUE AUTO SUPPLY in Arlington TX has THREE = 817-275-2381.
PARTS INTERNATIONAL in Farmers Branch TX has TWO = 888-727-0418.
GREEN SALES CO. in Cincinnati OH has TEN = 800-543-4959.
C2TZ16797C .. Left Hood Hinge / Obsolete
BOWMAN FORD SALES in Bowman ND has ONE = 701-523-3257.
KINSEL L/M has TWO.
ANTIQUE AUTO SUPPLE has TWO.
PARTS INTERNATIONAL has TWO.
GREEN SALES CO. has NINE.
BOTH hinges fit: 1961/66 F100/1100 / 1967/79 F800/1000 EDIT: TYPO! The hinges fit 1967/69 F800/1000.
Are you in the LA area? I know of a local wrecking yard that might have some good used hinges.
Old Oct 10, 2009 | 08:18 PM
1965 F-100's Avatar
1965 F-100
I had the same problem with those. I ended up elongating the holes to allow the hinges to be adjusted further.
Old Oct 11, 2009 | 01:09 PM
salf100's Avatar
salf100
Thanks for the info. I'm in the sacramento area. I think I'm going to elongate the holes on the one from LMC and buy NOS that Numberdummy posted.
Old Oct 11, 2009 | 02:49 PM
1965 F-100's Avatar
1965 F-100
As far as LMC goes... I bought a lot of parts from them and those were the only one's I had any problems with. Good luck and have fun
Old Apr 2, 2010 | 02:47 PM
1964F100's Avatar
1964F100
I also have a 64 cc needing hinges. I was wondering if 60' hinges are the same as the 64?
Old Apr 2, 2010 | 03:26 PM
Bill W's Avatar
Bill W
61-66 will only work for you app.
1960 is a different body style.
Old Apr 2, 2010 | 03:46 PM
garbz2's Avatar
garbz2
The hood hinges LMC sells are the same ones DC sells are the same NOS ones other people sell be aware that this is happening. Make sure they are genuine as the repops carry the correct ford part number and are sold as NOS.
Were the hinges tweaked that you replaced? Did you make sure the hood mounting location is correct as they tend to be pulled when the hinges tweak or the hood poped up during driving making any replacement moot as the underlying problem is still there. 1/8th or 1/4 inch tweak will cause the out of line you mention.
Garbz
Old Apr 2, 2010 | 03:47 PM
1964F100's Avatar
1964F100
Thanks for the reply bill.
Old Apr 2, 2010 | 10:28 PM
Old_Crow's Avatar
Old_Crow
This is gonna sound all wrong, but I replaced my hinges with a good set from a junk yard and the hood sat high in back no matter how much I lowered the hinges. If you loosen the top(or forwardmost)bolts that hold the hood to the hinge and put shims between the hood and the hinge it'll lower the back of the hood.
Can't explain the geometry as I'm a mechanic and not a body guy, but the body guy where I work told me to do that and it worked just fine. Got my hood sitting level with the cowl now.
Old Apr 2, 2010 | 11:10 PM
RJP66F100's Avatar
RJP66F100
KINSEL L/M has TWO.
BOTH hinges fit: 1961/66 F100/1100 / 1967/79 F800/1000.
Wow, I can't believe there are still some available (nos). Back 8 or 10 years ago my wife got some nos hood hinges for me & I thought then it was a small miracle.
Must be a few around because of the F800/1000 using them up till 1979.
Old Apr 3, 2010 | 03:11 AM
NumberDummy
This is somewhat common on trucks of this vintage, caused by...
Those used hinges may look OK, but looks can be deceiving.
All 1961/79 trucks have the same problemo.
Ppl slam the heavy hood down. Over time, this bends down the hood lock plate that the latch attaches to.
When this occurs, the hood flies up...tearing out the so-called safety catch that isn't worth 2 cents.
When the hood flies up, this causes the hinges to stretch! You can usually tell if the hinges have stretched, because the back of the hood will be higher than the cowl panel.
The hinges do not fit 1979. Post #2. I typed: Fits: 1967/79 F800/1000. 79 is a TYPO! The hinges fit 1967/69 F800/1000.
Old Apr 3, 2010 | 04:39 AM
Old_Crow's Avatar
Old_Crow
I didn't see the truck the hinges came off of, but all the pivot points have very little slack, and with minimal application of some spray white grease to the hinges and the latch mechanism the hood opens and closes more easily than many new vehicles(and about 1,000,000% better than it did with the old, bent up ones).
I'll live with the shims.
NoDough66
19
Feb 4, 2019 02:22 PM
48prerunner
13
Jul 22, 2016 05:44 PM
Shadowrider123
Jul 5, 2014 04:14 PM
THartman
Apr 22, 2013 09:55 AM
jerryst
Nov 24, 2012 12:53 PM
