1956 louvered hood
1956 louvered hood
does anyone know if the 1956 louvered hood is a factory piece or aftermarket? hood is all metal. i have a chance to purchase a 1956 f100 with a louvered hood, front mustang clip with a 289 mustang motor automatic for less than 2 grand. any comments on the hood would greatly be appriciated. thanks.
I'm not sure what the question is. Is the hood bad? Do you not like louvers? What's the problem?
Yes. Steel hoods are desirable. They are available in the aftermarket, although they are expensive. Most folks try to find a used one or a parts truck with a decent one. 53-55 hoods are the same. 56 hoods have an identical contour and fit, except they have two stove bolts thru the doubler at the rear of the peak and use different bolts at the hinges.
Outlaw56
12-14-2015 01:25 PM
Jasonnoel
12-29-2014 02:35 PM
hilltopfarms
03-17-2005 04:29 PM
