Sponsored by: Real Truck
Straight pipe.. causing check engine light?
Old Jan 21, 2012 | 06:33 PM
Bsentman888's Avatar
Bsentman888
so my 2003 f250 5.4L gas had a straight pipe when i bought the truck which was only 3 weeks ago.. they said the check engine light comes on because there is no catalytic converter which makes sense.. i ran the obd2 codes and one came back as the O2 sensor which is ok but im not sure what the other code is? these are the codes i got, anyone have any ideas if this is all ok? P1151 and P0155
also could the straight pipe cause it to run Lean? are their any cons to keeping it the way it is?
Old Jan 21, 2012 | 06:56 PM
Psyclopse's Avatar
Psyclopse
I am interested in the answer too. I also just got my truck- a 99 F250 5.4. It also has a straight pipe and the check engine light is on (otherwise seems to run fine). I haven't ran the codes though.
Old Jan 21, 2012 | 08:42 PM
The Metal Panda's Avatar
The Metal Panda
On these trucks, there is no O2 sensor on the cat.
The guy who just did my exhaust informed me of this so we ditched the cat. Ive had no issue with it.
(2001 5.4L)
Old Jan 21, 2012 | 10:36 PM
Milwaukee1979F150's Avatar
Milwaukee1979F150
I believed 2004 or above had oxygen sensors on both side of cat convertor. That what my friend told me. He on here. Freedom by 5.4L
I remove cat convertor on 01 F250 5.4L. No engine light on. Drove for 2000 miles before sold due paranoid about transmission issue. Reason why I remove cat. 200K miles by previous owner it look it was idle alot. Mpg was 12-13 after Cat delete it saw 15-17 mpg.
Old Jan 21, 2012 | 11:20 PM
cc250r's Avatar
cc250r
when i made my exhaust(no cat blowmaster 44 exits before passenger wheel) i took out the cat because i realized the only 02 sensors were before the cat and i have had it with no cat for about 1000 miles now with no check engine light and no problems.
Brannon Sanford
1997 - 2003 F150
Mar 8, 2019 12:17 AM
Kim's Hipster
Mar 30, 2011 07:41 PM
Chopper_WSP
Jul 31, 2008 08:58 PM
Cobra R
1997 - 2003 F150
Jan 26, 2005 04:21 PM
bhaider
Jan 8, 2004 07:05 AM
