storing engine block
Old Jan 21, 2012 | 04:23 PM
dixiestripes351's Avatar
dixiestripes351
i got 2 striped blocks and tryin to conserve room in my garage. i want to put them on the floor but i heard if u lay them a sertan way they will warp after a while. is this true? or dose it not matter
Old Jan 21, 2012 | 10:30 PM
85e150's Avatar
85e150
Have not heard that one. Just goop them up so they don't rust, and make sure bearing areas, bores and the deck areas are protected.
Old Jan 22, 2012 | 05:15 PM
jimbbski's Avatar
jimbbski
I have heard of this. That if you store a head or block in a way that doesn't spread the load that it can change shape. But we are talking a very small amount, like just a few thousands of an inch. In a straight 6 it could make a difference but on a V8 I don't think so.
Old Jan 25, 2012 | 06:14 PM
dixiestripes351
gotchya i have had them standing stright up for a couple years and dont plan on building them for another year or so cuz money is tight
Old Jan 25, 2012 | 06:32 PM
Beechkid's Avatar
Beechkid
well, its stretching it a bit....
Easy storage on the floor..........set it on the flywheel (on a wood base) or build a 2x8 box that batches the outer edge of the oil pan....or just set it on a used tire...spray with wd40 (not oil- because it will not stop the rust), bag it with a trash bag and you're good to go.
Old Jan 26, 2012 | 12:40 AM
Beanscoot's Avatar
Beanscoot
Storing engines
I have to disagree with the idea that WD-40 is a better rust preventative than engine oil. I have found that WD-40 tends to evaporate over a short time leaving very little protection behind, whereas parts wiped with oil retain the oil film indefinitely, along with an excellent rust protection.
I agree that blocks of wood or equivalent spacers should be put under engines stored on the floor as moisture does come up through concrete in greater or lesser amounts. Having the items spaced up from the floor allows the moisture to be dissipated harmlessly into the air. If large metal items are directly on the floor, sometimes the moisture will condense on their undersides.
Old Jan 27, 2012 | 08:48 PM
Boba Fett's Avatar
Boba Fett
What you also want to do is knock the dowel pins in the back of the block out that align the bellhousing.... If set the block down on them the weight of the block can cause them the crack the holes that house these pins....
I like to smear vasoline in the bored and leave the main bearing installed.... Then cover it in a trash bag.... Set it on some wood so it isnt on the floor either... In case of flooring...
Old Jan 27, 2012 | 08:49 PM
Boba Fett's Avatar
Boba Fett
Flooding...
Old Jan 28, 2012 | 09:45 PM
Beanscoot's Avatar
Beanscoot
Yes, definitely install the main bearing caps. They are individually fitted to the block. If not reattached, they tend to get permanently separated after a few years, rendering the block useless.
Old Jan 29, 2012 | 08:46 AM
Boba Fett's Avatar
Boba Fett
Beenscoot is correct.... A block stored with the caps on it will be useless... This might be what you were referring to earlier about warping.... I like to keep the old bearings in too
Talyn
26
Apr 4, 2011 11:54 PM
backwoodspuller
Oct 23, 2006 03:25 AM
t_dickie
General Automotive Discussion
Dec 14, 2004 02:27 PM
lilpig88
15
Mar 16, 2003 10:32 PM
trinogt
Sep 6, 2002 08:13 AM
