Block Curiosity
Old Apr 1, 2011 | 08:43 AM
Talyn's Avatar
Talyn
Block Curiosity
What is the best block to build a motor from between the 94-03 range?
Old Apr 1, 2011 | 04:08 PM
Cuda_jim's Avatar
Cuda_jim
Not sure if there are better blocks but some of the newer engines have powdered metal rods. The NBS forums have pictures of the carnage from pushing the PMR's too far so you may want to steer clear of them if you are building a bullet.
Old Apr 1, 2011 | 04:39 PM
Talyn's Avatar
Talyn
Well. I'm not 100% sure on the differences between the block years, but there were at least 4 or 5 castings just for the OBS If I recall it correctly.
But I wouldn't want to pass up a deal on a SD block if it was usable or better.
Old Apr 1, 2011 | 06:00 PM
Cuda_jim's Avatar
Cuda_jim
Here's some reading for ya....maybe you've seen this before but..........
TheDieselStop.Com - www.thedieselstop.com
Cover Page pictures from hobbies & interests photos on webshots
Old Apr 1, 2011 | 06:17 PM
deadsenator's Avatar
deadsenator
Somewhere I have a link that 'splains the PMR issue and the serial numbers to look for. I can dig further if so desired.
Old Apr 1, 2011 | 06:36 PM
Talyn's Avatar
Talyn
I doubt i'm going to be that picky, but all the info is helpful.
Its so much easier having a block and a truck to take the block to the machine shop with ya know?
Get the block work done and pull my motor and start swapping parts.
Old Apr 1, 2011 | 06:37 PM
Talyn's Avatar
Talyn
Thanks Jim, was able to rep you for once.
Old Apr 1, 2011 | 07:01 PM
strokin'_tatsch's Avatar
strokin'_tatsch
The general concensus is that the OBS block is less likely to crack. A '96 or '97 block. Think I'd rather have a '97 block if I was looking.
IIRC the survey done by PHP confirmed this. Also IIRC the '99 models showed more broken blocks than others. Probably due to bad tuning due to the split year and tuners not having the proper PCM code. Unfortunately we no longer have access to the PHP survey to confirm what I think I remember. LOL
Old Apr 1, 2011 | 07:06 PM
MADVAN's Avatar
MADVAN
Choice of blocks are the one's with mech fuel pump boss.
B
Old Apr 1, 2011 | 07:29 PM
Talyn's Avatar
Talyn
haha, Thanks Mad Van. =)
good info travis. thanks.
Old Apr 1, 2011 | 07:40 PM
TheTowingCowboy's Avatar
TheTowingCowboy
Th eblocks in OBS 94.5-96 are spouse to be the strongest ones. Cause they were cast heavier then as the block evolved it was lightened up and not so thick. Oh oh oh gett a stroker kit for it!!!!!
Old Apr 1, 2011 | 07:53 PM
strokin'_tatsch
Not exactly true... The later blocks actually got thicker in the valley area.. Also, the '94.5-'95 blocks did not have bracing in the lifter galley areas like the '96+ blocks, so I'd have to assume they are not quite as stiff.
Also there is no such thing as a stroker kit for us nor do I think it'd help us much..
Old Apr 1, 2011 | 08:00 PM
Talyn's Avatar
Talyn
I think that was a joke Travis. haha
Power Stroke...
ahh.
Found a 97 with trans, hoping its a zf5.
Really cheap.
Old Apr 1, 2011 | 08:01 PM
NavyMIDN08's Avatar
NavyMIDN08
Weld and offset grind?
no... bad idea. Don't do that, don't even think of doing that...
Old Apr 1, 2011 | 08:06 PM
TheTowingCowboy
What you want for the other ZF5 tranny?? =D
And the stroker kit actually was mentioned out of curiosity cause they make a 427 kit for the 6.6 D-Max, and i dont see how it couldnt help us any. Stroker kits are known for adding more low end torque... But for the money one would be it would probably only be a 'last thing to get last little amount'
